IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, April 19th at 5:00 AM US/Pacific.
Hi all, I kindly require help on the following. Assume I have a class as follows
class abc extends uvm_object; // a kind of config class
`uvm_object_utils(abc)
config_class config_h;
function new(string name = "abc");
config_h.a = 5;
and another class as follows:
class def extends uvm_test; // base test for the environment
`uvm_component_utils(def)
// Assume that config_class handle config_h has already been created using type_id::create, and is set in uvm_config_db
abc_handle = abc::type_id::create("abc_handle"); // -> does this execute the "new()" constructor in config_class?
uvm_config_db #(abc)::set(this, "*", "abc_handle", abc_handle);
abc.config_h = config_h;
I see a null object access error on the line config_h.a = 5. Is this because this line of code is executed before the handle is assigned to the class?
The only way to construct an object in SystemVerilog is by calling new(). Just add a $display statement in the constructor to see when it is called.
A ‘null object access error’ means you are using an uninitialized handle. Either step through the code with a debugger or print the value of the handles before line 5 with %p:
$display("config_h=%p", config_h);
The last line of the build_phase() won’t compile. ‘abc’ is a class name, not a handle.
In reply to vk7715:
There are several issues here.
Hi Chris, thank you for your reply.
I also would like to know the answer to another question I had in the comments, does calling type_id::create end up calling the “new” constructor of that class?
Example, does abc::type_id::create(“abc_handle”); call “new” function in class abc?
That’s why I said to put a $display() in abc::new() so you can see for yourself. If you have access to a good debugger, you can try stepping through the create() call, but it goes deeper than the Titanic, so you might be there for a while. :-)
In reply to vk7715:
Hi Chris,
I put a $display() and saw for myself – type_id::create calls ‘new’ of the class. Thank you.
On a side note, what debugger do you recommend for stepping through UVM code? And are there any tutorials teaching the same?
