Is there any difference between the following two codes in the hardware? assume a, b and c as single bit signals.
always_comb
a=b&c;
assign a=b&c;
always_comb
a=b&c;
assign a=b&c;
In reply to svishnu:
module m;
bit a, b;
logic l1, l2;
wire w1, w2;
assign a=!b;
always_comb b=l2;
assign l2=1'b1;
always_comb l1=!l2;
assign w1=1'b0;
/// always_comb w2=w1; // *** ILLEGAL
// Net type cannot be used on the left side of this assignment.
// The offending expression is : w2
// Source info: w2 = w1;
There is no difference in resulting hardware. With this simple example, it is hard to see the benefit of always_comb versus assign. The assign statement is a much lower level construct as you can only define one signal with one equation. You can be much more expressive with the always_comb.
I like the implications of each:
They both are one liner, but the connotations are different
Of course the always_comb can be more complex with the begin / end
Ben
Hello,
How about the latch infer during synthesize ?
does always_comb infer latch ?
In reply to kddholak:
always_comb is a declaration of intent stating that the block will consist of combinational logic only. You need to use always_latch to infer a latch.
from hardware point of view in always_comb we use the signals as reg so there maybe some storage element but in assign statement there is only single wire.
In reply to shanya:
If the structure with the always_comb implies storage, the compiler will flag this as an error.
Also, if the always_ff does not imply storage, it’s an error.
The “always” can do anything.
Ben Ben@systemverilog.us
