sam497
August 24, 2023, 7:05pm
1
I am trying to solve a constraint of instruction set where I need add instruction 20 times MUL less than 5 timed XOR less than 5 time
typedef enum int { ADD_1,SUB_1,MUL_1,NAND,DIV,AND,OR,NOR,XOR} instruction;
rand instruction inst[];
constraint size_1 {
inst.sum with (int'(item==SUB_1) inside {0,2,8,16});
inst.sum with (int'(item==MUL_1) inside {[0:5]} );
inst.sum with (int'(item==XOR) inside {[0:5]} );
inst.sum with ((item==ADD_1) == 10 );
for ADD instruction only constraint I am seeing constraint solver Issue
Solver failed when solving following set of constraints
rand bit[30:0] inst.size(); // rand_mode = ON
rand ex01_pkg_serial_child_sequence_11_0::instruction fv_temp_111; // rand_mode = ON
rand bit[0:0] fv_temp_114; // rand_mode = ON
rand bit[0:0] fv_temp_115; // rand_mode = ON
rand bit[0:0] fv_temp_116; // rand_mode = ON
constraint size_1 // (from this) (constraint_mode = ON) (../ex01/serial_child_sequence.sv:59)
(fv_temp_116 == (inst.size() * ((fv_temp_111 == ex01_pkg_serial_child_sequence_11_0::instruction::ADD_1) == 10)));
((fv_temp_114 >= fv_temp_115) && (fv_temp_114 <= fv_temp_116));
fv_temp_114;
if I put Add instruction inside operator it’s passing.
sam497
August 24, 2023, 7:06pm
2
In reply to sam497 :
constraint size { inst.size() inside {[80:100]};}
constraint size is 80 to 100.
The sum of all instructions needs to be in the range of the size of the inst array.
sam497
August 25, 2023, 8:58am
4
sorry for confusion my question is about issue coming when I constraint add to 10 over the size of 100
constraint size_1 {
constraint size_1 // (from this) (constraint_mode = ON) (…/ex01/serial_child_sequence.sv:59)
fv_temp_114;
I’m sorry, I misread your original code. It would have helped to show a complete code formatted example. The problem is with your placement of parentheses in all the sum constraints and that you did not cast item==ADD_1 to an int. Here is the corrected code.
class istream;
constraint size_1 {
inst.sum with (int'(item==SUB_1)) inside {0,2,8,16};
inst.sum with (int'(item==MUL_1))inside {[0:5]};
inst.sum with (int'(item==XOR)) <=5 ;
inst.sum with (int'(item==ADD_1)) == 10 ;
istream is = new;
initial repeat(10) begin
assert(is.randomize());
$display("%0p",is.inst);
