Conditional Statement in 'repeat loop'
Hello!
Here is a sample code to verify the transitional bins. I’ve repeated the loop randomly for 100000 times for functional coverage to become 100%.
Now I want to add a condition in the repeat loop that at coverage = 100%, the block has to terminate. What changes should I make to the code?
module transition_bins;
	bit [3:0] data;
	covergroup cg;
		c1: coverpoint data {
				      bins d1[]   =  (9 => 3);
		         	      bins d2[]   =  (4 => 8 => 12);
				      bins d3[]   =  (2,3 => 4,5);
	 		              bins d4[]   =  (2,3,4 => 5,6,7);
				      bins d5[]   =  (4'hd[*2] => 5,6,7);
				      bins d6[]   =  (7[*2:4]);
				      bins d7     =  (9 => 5[->3] => 11);
				      bins d8     =  (12 => 15[=3] => 10);
	endgroup: cg
	initial
			cg c = new;
			repeat (100000) //what should I change so that when the coverage is 100%, the repeat block terminates?
					data = $random;
					$display("\ndata = %0h",data);
					c.sample();
			$display("\nCoverage = %0.4f%%",c.get_inst_coverage());
Thankyou!
In reply to Shashank Gurijala:
See the break statement.
you can do something like this:
   if (c.c1.get_coverage()==100.0)
       $display("Total coverage = %6.2f", c.c1.get_coverage());
       $finish();
// Code your testbench here
// or browse Examples
 bit [3:0] data;
 covergroup cg;
	endgroup: cg
	initial
			cg c = new;
					data = $random;
					c.sample();
               if (c.get_inst_coverage==100.00) break;
In reply to rag123:
Yeah i did the same using if loop you tried. But I want to repeat the block exactly until coverage is 100% without mentioning any integer in the repeat block.
 bit [3:0] data;
 covergroup cg;
	endgroup: cg
	initial
			cg c = new;
          while (c.get_inst_coverage!=100.00) //what should I change so that when the coverage is 100%, the repeat block terminates?
					data = $random;
					c.sample();
In reply to rag123:
I tried using the forever loop and if loop inside and then break it. But I want to know if its possible to do it in repeat loop.
And using while is another idea, too. Thanks!
