I understand SV doesn’t support compile-time polymorphism i.e. function overloading evidently.
Look at the example below and please help me understand two queries
Is this not a candidate of ‘function overloading’ as the signature of the function ‘add’ in the base class and derived class are different?
If yes, is this supported accidentally or conciously? Note, this is compile-error free and can be executed.
class Base;
function int add (int a,
int b);
return (a + b);
endfunction:add
endclass:Base
class Derived extends Base;
int b,
int c);
return (super.add (a,b) + c);
endfunction:add
endclass:Derived
module tb;
Derived d_obj = new ();
initial
$display ("Sum : %0d", d_obj.add (1,2,3));
endmodule:tb
Prem
In reply to run2prem:
Function overloading would be calling different implementations of a function based on the signature alone. Your code calls Derived::add based on the type of class variable d_obj. You must call it with 3 arguments. This is because add is not a virtual method.
Yes got it and agreed.
But within the ‘Derived’ class scope, we get two ‘add’ methods with different signatures. Yes, of course user has to resolve the call himself by specifying this. or super.
My query is
This is a case of polymorphism or not?
If so, is this function overloading or overriding?
I’m not sure how C++ or other OOP language handles this.
Prem
This is not polymorphism. Polymorphism is the same code behaving differently under different circumstances. SystemVerilog has compile time, or static polymorphism when you parameterize a module or class. Run-Time or dynamic polymorphism is implemented with virtual methods.
What you have done is override the add function in the Derived class. This “hides” the original add function.
You may want to read: Parameterized Classes, Static Members and the Factory Macros - Verification Horizons
