All,
I have been attempting to compile my SPB testbench, but have came across a compilation error which I believe is caused by the testbench package which comprises of my `include macros. The package is shown below:
package spb_pkg;
import uvm_pkg::*;
`include "uvm_macros.svh"
`include "spb_data_item.sv"
`include "spb_agent_config.sv"
`include "spb_env_config.sv"
`include "spb_seq_lib.sv"
`include "spb_sequencer.sv"
`include "spb_driver.sv"
`include "spb_monitor.sv"
`include "reg2spb_adapter.sv"
`include "spb_agent.sv"
`include "spb_environment.sv"
//`include "spb_coverage.sv"
//`include "spb_scoreboard.sv"
`include "spb_test_base.sv"
endpackage : spb_pkg
I use this package in my top level module as shown below:
`include "spb_if.sv"
`include "spb_pkg.sv"
//Start Of Module
module spb_top;
//Import packages and include uvm macros
import uvm_pkg::*;
import spb_pkg::*;
The error that I receive is regarding my spb environment component, so for completion the beginning of the environment code is shown below:
//Start Of Class
class spb_environment extends uvm_env;
//Class Data Members
spb_agent spb_ag; //Handle to the SPB agent
spb_env_config spb_env_cfg; //Handle to the environment configuration
//spb_reg_coverage spb_reg_fc_collector; //Handle to SPB functional coverage subsciber
//spb_scoreboard spb_sb; //Handle to SPB scoreboard
reg2spb_adapter reg2spb; //Handle to the adapter
uvm_reg_predictor #(spb_seq_item) spb2reg_predictor; //Handle to the predictor
//Automate frequently used methods, e.g get_full_name(), copy(), compare() etc.
//Fields set here can be adapted higher in the environment hierarchy
`uvm_component_utils (spb_environment)
//Standard constructor for environment
function new (string name = "spb_environment", uvm_component parent);
super.new(name, parent);
The error that I receive is as follows:
ncvlog: *E,NPITEM (…/vip/spb_uvc/sv/spb_environment.sv. 10|4): Not a valid package item: ‘module/udp instance’ [SystemVerilog]/
(include file : ....../vip/spb_uvc/sve/spb_top.sv line 10, include file: …/vip/spb_uvc/sv/spb_pkg.sv line 23, file : …/vip/spb_uvc/sve/spb_top.sv line 1)
I guess that this error is caused by the ordering of my `include macros, however, I cannot understand why I am getting such an error and how I would remove this error. Any suggestions would be much appreciate.
Regards,
Owen
In reply to owenjarvie:
Can you tell us what is in the preceding included file, spb_agent.sv ? I feel that may hold some clues.
In reply to Richard Hamer (EnSilica):
Richard,
The SPB agent is very simple. It builds and connects components as required depending on the active or passive bit set in the agent configuration. The code is shown below:
//Start Of Class
class spb_agent extends uvm_agent;
spb_monitor spb_mon ; //Handle to SPB monitor
spb_driver spb_drv ; //Handle to SPB driver
spb_sequencer spb_sqr ; //Handle to SPB sequencer
spb_agent_config spb_ag_cfg ; //Handle to agent configuration
virtual spb_if spb_vif ; //Handle to virtual interface
uvm_active_passive_enum spb_active; //Controls whether SPB agent is active or passive, overwrite in config
uvm_analysis_port #(spb_data_item) spb_ag_port; //Agent Port
`uvm_component_utils_begin (spb_agent)
//`uvm_field_object (spb_mon, UVM_ALL_ON)
//`uvm_field_object (spb_drv, UVM_ALL_ON)
//`uvm_field_object (spb_sqr, UVM_ALL_ON)
//`uvm_field_object (spb_ag_cfg, UVM_ALL_ON)
`uvm_field_enum (uvm_active_passive_enum, spb_active, UVM_ALL_ON)
`uvm_component_utils_end
//Standard constructor for agent
function new (string name = "spb_agent", uvm_component parent);
//Build interface, agent configuration and agent components depending on whether agent is set to be
//active or passive. Create agent port using the new() method
function void build_phase (uvm_phase phase);
super.build_phase (phase);
//Create the agent port
spb_ag_port = new("spb_ag_port", this);
//Retrieve agent configuration from the database
if (!uvm_config_db #(spb_agent_config)::get(this, "", "spb_agent_config", spb_ag_cfg)) begin
`uvm_fatal ("AGT_CFG", "SPB Agent Config Not Found")
//Create config if it doesn't exist
if (spb_ag_cfg == null) begin
spb_ag_cfg = spb_agent_config::type_id::create("spb_agent_config", this);
//Retrieve interface from the database
if (!uvm_config_db#(virtual spb_if)::get(this, "", "spb_vif", spb_vif)) begin
`uvm_fatal ("AGT_NOVIF", "Could not get virtual interface from database.")
//Create a driver and a sequencer if agent is active
if (spb_ag_cfg.spb_active == UVM_ACTIVE) begin
spb_drv = spb_driver::type_id::create("spb_drv", this);
spb_sqr = spb_sequencer::type_id::create("spb_sqr", this);
//Monitor created whether active or passive configuration
spb_mon = spb_monitor::type_id::create("spb_mon", this);
`uvm_info ("SPB_AG_BUILD", "SPB Agent Build Phase Complete", UVM_LOW)
endfunction : build_phase
//Connect driver response port to sequencer if the agent is configured to require such a connection.
//Connect driver port to the sequencer if the agent is in active configuration
function void connect_phase (uvm_phase phase);
super.connect_phase (phase);
//If the spb agent is active connect the driver to the sequencer
//If the driver has to send a response back to sequencer
if (spb_ag_cfg.spb_has_rsp != 0) begin
spb_drv.rsp_port.connect(spb_sqr.rsp_export);
`uvm_info ("SPB_AG_CONNECT", "Active SPB Agent Requires Response port", UVM_LOW)
//Connect driver to sequencer
spb_drv.seq_item_port.connect(spb_sqr.seq_item_export);
`uvm_info ("SPB_AG_CONNECT", "Active SPB Agent::Driver Connected to Sequencer", UVM_LOW)
else begin
`uvm_info ("SPB_AG_CONNECT", "Passive SPB Agent::No Connections", UVM_LOW)
endfunction : connect_phase
endclass spb_agent
//End Of Class
In reply to Tudor Timi:
Thanks Tudor Timi for pointing out my stupid mistake, much appreciated!
