Hi ,
I want to define some code based on the macro value of `define
Let us suppose that `define TEST 1
I want to enable some code if `TEST define value is ‘1’
Regards,
Phani
Hi ,
Regards,
Phani
In reply to kpkrishna:
One can use ifdef... endif to check whether the macro is defined or not. Moreover, one can use an optional generate block to test the value of macro/parameters.
module top();
`ifdef MY_MACRO
if(`MY_MACRO == 1) begin // If MY_MACRO is defined and value is 1
initial $display("MY_MACRO equal to 1");
end else begin // If MY_MACRO is defined and value is not 1
initial $display("MY_MACRO not equal to 1");
`else
initial $display("MY_MACRO not defined"); // If MY_MACRO is not defined
`endif
Here if MY_MACRO is defined and value is 1, then the first initial block will be executed.
Refer to this section for more information.
In reply to sharvil111:
Sometimes, you can check the macro value in procedural code. There’s no performance penalty because the way compilers propagate constants and eliminate dead code.
module top();
`ifdef MY_MACRO
initial if(`MY_MACRO == 1) begin // If MY_MACRO is defined and value is 1
`else
`endif
I don’t want the else block to get compiled. Will it get compiled in this case
And i want to use in class
yes Macro can be used in class too. And for your formal query dave_59 already answered it will eliminate else code if value is set to 1
You can remove the else/else conditions as per your requirement. As a side note, else is a compiler directive so it will not compile if MY_MACRO is defined.
`define TEST 5
class A;
rand int x;
if (`TEST == 32'd45)
`define TEST1
$display("TEST 1 DEFINE");
`define TEST0
`ifdef TEST1
$display("TEST 1 DEFINED ");
`else
KKKKKKKKKKKKKKKK
`endif
module test;
A a = new();
initial
a.randomize();
Can you help me in finding the issue here. Since TEST define value is 5 , i should get compilation error. But i am not getting
Macros are processed in the preprocessor, and are constant at runtime. Your ‘if (`TEST == 32’d45)’ statement is not evaluated by the preprocessor. Which means both TEST1 and TEST0 are being defined.
To the preprocessor, your code simply looks like:
`define TEST 5
// some text
`TEST
// some text
`define TEST1
// some text
`define TEST0
// some text
`ifdef TEST1
// some text
`else
// some text
`endif
// some text
