this assertion is passing(as I dont see any errors in simulation.log), but for my double-confirmation I wanted to display some statement to know if this part of assertion is working
for the `uvm_info I’m using I’m getting error as -
The above error is most likely due to the missing include of uvm_macros.svh file. Now, on your Q of Property/SVA debug, yes, quoting an example from a recent post:
assert property( ab ) $display("T:%0t Pass",$time);
else $display("T:%0t Fails",$time);
Replace $display with uvm_info as you wish (BTW adding a Pass action block is a really bad idea, instead, use your tool’s options to print stats at the end).
Also, you can do seq-matching feature to print messages in a longer, temporal SVA as well.
System task like $display is used along with a sequence expression.
property p1;
( $rose(req), $display("req received at time:%0t",$time)) |=> ($rose(grant)[->1], $display("grant received at time:%0t",$time));
Note: The $display() executes only if the sequence matches
One can also use 1 ( always true ) as a sequence expression
property p2;
$rose(req) ##0 (1,$display("req received at time:%0t",$time)) |=> $rose(grant)[->1] ##0( 1,$display("grant received at time:%0t",$time));
Turns out the expansion of macro `uvm_info prohibits its use as sequence_match_item.
( The macro internally calls function ‘uvm_report_info’ in class uvm_report_object which then calls function ‘report’ in class uvm_report_handler )
Try the following which works:
function void disp();
`uvm_info("ASSERTION","INSIDE ASSERTION MODULE",UVM_MEDIUM)
property p1;
@(posedge core_clk) $fell(g1) |-> ($rose(g3) throughout $fell(g4)) ##80 $rose(g5) ##0(1,disp());
// disp() can also be attached to sequence $rose(g5). Eg: ... ##80 ($rose(g5),disp() )
To re-use function ‘disp’ for different messages, add the respective 3 argument type of `uvm_info to ‘disp’
