Bitwise toggle coverage for a bitvector
In reply to albert:
class xyz ;
bit[31:0] address;
bit[31:0] ADDR;
covergroup access();
  addr : coverpoint ADDR { bins Addr[16] = {[0:address]}};
endgroup
function void calc();
  access.sample();
fucntion new();
  address = 'h10000;
  access = new();
task run();
 forever begin
    calc();
I need to use the ref keyword in order to achieve the behavior I want. But I see 1 bin getting created if I try to do this::
class xyz ;
bit[31:0] address;
bit[31:0] ADDR;
covergroup access(ref bit[31:0] Addr);
addr : coverpoint ADDR { bins addr[16] = {[0:Addr]}};
endgroup
address = 'h10000;
access.sample();
fucntion new();
access = new(address);
task run();
forever begin
calc();
In reply to albert:
The value of ADDR is read when calling the covergroup’s constructor. That is when the bins for the coverpoint are created. There is no more bin creation after constructing the covergroup.
So if ADDR has the value 0 when executing the statement
Then
will be interpreted as
 addr : coverpoint ADDR { bins addr[16] = {[0:0]}};
which creates one one bin for the value 0.
You should have gotten a warning like
** Warning: (vsim-8546) The number of values specified ‘1’ is less than the size ‘16’ of fixed-size array bin ‘Addr’ in Coverpoint ‘addr’ of Covergroup instance '/top/xyz::access '. The ‘15’ empty bins will not contribute towards coverage.
Thanks for the reply. Yes i did see that warning.
Actually in the function I have calculated the range of address which i want to use in my covergroup.
Basically i want to do this
memory_range : coverpoint range {bins addr = {[base_addr, final_addr]};}
which will be dependant on the size of the memory for which i have defined a function. The size and base_addr are read from registers inside the function.
bit [3:0] size;
register read to get size;
register read to get base_addr;
case(size)
4’b0000: begin
Max_addr = ‘h10000;
Final_addr= base_addr+max_addr;
covergroup.sample();
4’b0001: …….
How should I access the base addr and final addr from the function in my covergroup?
In reply to albert:
Could you please suggest a way in which the above scenario can be achieved?
In reply to albert:
You still have not explained your situation very well. Functional coverage in SystemVerilog works by creating in set of value bins associated with a coverpoint, and a set of coverpoints or grouped within a covergroup. The bins are set up once during the covergroup’s constructor. The the covergroup repeatedly samples the values of the coverpoint, and the matching value bins are incremented with hits. You call sample() repeatedly hoping the every bin gets hot.
You need to explain what value will be repeatedly sampled and compared with the predefined set of bin values. Perhaps you need to show an example set of data that would be sampled, and explain which bins would be hit those values.
The basic idea is to create bins with the range of base address and final address.
The base address is programmed through register which is again dependant on size being programmed in another register.
So based on what size is being programmed, i have calculated the max address and final addr would be base + max.
i want to use the values inside the function (like base addr and final addr) in the covergroup.
I want to sample all the addresses which fall within that range. preferably create 16bins and have the address range split across these 16bins.
The problem i am facing now is that the base and final addr is not visible in the covergroup and only 1bin gets created as such.
In reply to albert:
Hi Dave, Can we have a function inside the coverpoint like below?
covergroup memory_access(string name) with function sample(bit[47:0] sb_addr);
mrom_erom_mmio_range : coverpoint sb_addr {
                          function bit[47:0] QUEUE[$] mem_region();
                            bit [47:0]   max_addr;
                            bit [47:0]   base_addr;
                            bit [3:0]    size;
                            bit[47:0] queue [$];
                            bit [47:0] i;
                                max_addr = 48'h1000000;
                                for(i=base_addr; i<=(base_addr+max_addr); i++) begin
                                queue.push(i);
                                return queue;
                        bins addr = mem_region();
endgroup
function void memory_space();
        new_addr = {item.addr[5], item.addr[4], item.addr[3], item.addr[2], item.addr[1], item.addr[0]};
        memory_access.sample(new_addr);
endfunction: memory_space
function new (string name, ovm_component parent);
super.new(name, parent);
memory_access = new({“memory_access_”, name()});
endfunction : new
task run();
forever begin
memory_space();
endtask : run
Currently on compiling this code, i see syntax error
92: token is ‘function’
Could you provide your input?
In reply to nisreenj:
you can use perl script also
//+vpp+ foreach my $i (0…31) {
cp_interrupting_csrmask##$i## : coverpoint m_csr_intr_mask.interrupting_csrmask[##$i##];
//+vpp+ }
it will do the for 0 to 31 just 3 steps :)
Thanks for sharing the solution. The problem with maximum_width is that simulator expects an equivalent type for ref formal ‘vector’ (ie. Questa will return error 8282).
However, one can override built-in sample method:
covergroup cgmaskbit(input bit [31:0] position) with function sample (bit [MAX_WIDTH-1:0] vector);
  pos: coverpoint (position & vector) !=0;
  option.per_instance = 1;
endgroup
Hi Dave
Do you have logic for covering of bits from toggling 1=> 0 and 0 => 1 ?
In reply to rajivdesh:
Same as my original example with transition bins
covergroup cgmaskbit(input bit [31:0] position, ref bit [31:0] vector);
  pos: coverpoint (position & vector) !=0 {
   bins tr[] = (1=> 0,0 => 1 ;}
endgroup
