Functional Coverage for larger bit size
Hi All, as discussed above, needs some clarification for the following
Example_1 :
covergroup cgmaskbit(input bit [31:0] position, ref bit [31:0] vector);
  pos: coverpoint (position & vector) !=0 {
   bins tr[] = (1=> 0,0 => 1 ;}
  option.per_instance = 1;
endgroup
cgmaskbit cgmaskbits[32];
foreach (cgmaskbits[i]) cgmaskbits[i] = new(1'b1<<i,m_csr_intr_mask.interrupting_csrmask)
This Example_1 is ensuring that each bit in in the 32bit is toggling from zero to one and one to zero, means, this will create two bins
1 bin to 1=>0 transition
1 bin to 0=>1 transition
Is this understanding is correct?
Example_2 :
endgroup
This Example_2 is ensuring that each bit is going HIGH at least once.
bit [31:0] addr;
addr[31], addr[30]....addr[0]  should be set to ONE
This is like one hot encoding
This will create 32 bins.
In the above link, many examples have been discussed, hence wanted to have a clarification.
Kindly confirm 1 and 2
Thank you
Both examples create 64 bins with each covergroup instance having 2 bins.
