I had a doubt regarding assertions.Can assertions can be done on self check which will be written in ENVIRONMENT or it is done only on DESIGN.If we can write on Self check then how to perform assertions on self check as it will be in class and how to use bind in this particular situation per say we can perform in different block as in bind we need to instantiate.An example will be appreciated
Thank you.
In reply to Adharsh_07:
I address the isue of assertions and classes in my papers.
Basically you have 3 choices:
- Use the interface to write SVA and copy the needed class variables into the interface
- Use the interface to write SVA by using class variables declared as static
- Use tasks in the class instead of SVA
See my papers
SVA Alternative for Complex Assertions
Understanding the SVA Engine,
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
- Free books:
- Component Design by Example https://rb.gy/9tcbhl
- Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
- A Pragmatic Approach to VMM Adoption
http://SystemVerilog.us/vf/VMM/VMM_pdf_release070506.zip
http://SystemVerilog.us/vf/VMM/VMM_code_release_071806.tar
- Papers:
Verification Horizons
Reflections on Users’ Experiences with SVA, part 1
Reflections on Users’ Experiences with SVA, part 2
Reflections on Users’ Experiences with SVA - Part II
Understanding and Using Immediate Assertions
SUPPORT LOGIC AND THE ALWAYS PROPERTY
http://systemverilog.us/vf/support_logic_always.pdf
SVA in a UVM Class-based Environment
SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter.
