Assertion with variable declaration in SVA
How to implement variable delay in SV?
condition : ##[a:b] when a and b are variables?
eg: first_match((a && $fell(sig2)), delay1=TMAX, delay2=TMIN) |=>
(need to implement delay between TMIN and TMAX,both are variables)
In reply to christin kripa John:
The easiest solution is explained in my paper
Dynamic delays and repeats
ISSUE: Using dynamic values for delays or repeats is illegal in SVA; how can this be easily resolved?
int dly1=2, dly2=7; // module variables
ap_abc_delay: assert property($rose(a) ##dly1 b |-> ##dly2 c); // ILLEGAL SVA
ap_abc_repeat: assert property($rose(a) |-> b[*dly1] ##1 c); // ILLEGAL SVA
SOLUTION: The concept is very simple, the repeat or delay sequence is saved in a package with two defined sequence declarations that include arguments.
http://SystemVerilog.us/vf/sva_delay_repeat_pkg.sv
package sva_delay_repeat_pkg;
 sequence dynamic_repeat(q_s, count);
 int v=count;
 (1, v=count) ##0 first_match((q_s, v=v-1'b1) [*1:$] ##0 v<=0);
 endsequence
 sequence dynamic_delay(count);
 int v;
 (1, v=count) ##0 first_match((1, v=v-1'b1) [*0:$] ##1 v<=0);
 endsequence
endpackage
// The package can be applied as follows:
// SystemVerilog.us/vf/sva_delay_repeat.sv
import sva_delay_repeat_pkg::*;
 timeunit 1ns; timeprecision 100ps;
 bit clk, a, b, c=1;
 int r=2;
 sequence q1; a ##1 b; endsequence
 ap_abr: assert property(a |-> dynamic_repeat(q1, r) ##1 c);
 ap_delay:assert property(a |-> dynamic_delay(r) ##0 b);
  1. VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
  2. http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
  3. “Using SVA for scoreboarding and TB designs”
    http://systemverilog.us/papers/sva4scoreboarding.pdf
  4. “Assertions Instead of FSMs/logic for Scoreboarding and Verification”
    October 2013 | Volume 9, Issue 3 | Verification Academy
  5. SVA in a UVM Class-based Environment
    FREE BOOK: Component Design by Example
    … A Step-by-Step Process Using VHDL with UART as Vehicle
    http://systemverilog.us/cmpts_free.pdf
Here,both the delay values are variables.(variables get value only after a function call)
How can we write a simple assertion on this?
In my SVA book I provide th following solutions:
11.4.2 Range delay (e.g., ##[2:v] b
The first element of the range must be a constant, and cannot be a variable. The second element is a variable. Below is an equivalent assertion for : // /11.4/m5067_gen_options.sv
ap_range_fix: assert property($rose(a) |-> ##[N:v] b);
property p_range_equivalent; // Equivalent implementation
int local_v; // this is an internal local variable defined by the tool
  $rose(a) |-> (1, local_v = v-N)
  ##N 1'b1 ##0 first_match((1, local_v=local_v - 1)[*0:$] ##1 (b || local_v<=0))
  ##0 b;
ap_range_equivalent: assert property(p_range_equivalent);
// generate option
generate for (genvar g_i=0; (g_i<8); g_i++) begin
  if (g_i >= N)
  ap_range_gen: assert property (v==g_i && $rose(a) |-> ##[N:g_i] b);
end endgenerate
Also, read my article in
verificationacademy.com/news/verification-horizons-march-2018-issue
For your problem, the following works and is tested with the below code using static values for the range.
    property p1;
        int v_r1, v_r2, v_diff;
        ($rose(a), v_r1=r1, v_r2=r2, v_diff = v_r2 - v_r1) |->
        dynamic_delay(v_r1)  ##0
        first_match((1, v_diff=v_diff - 1)[*0:$] ##1 (b || v_diff<=0))
        ##0 b;
    a_p1: assert property(@ (posedge clk) p1);
testbench
    int v=count;
    endsequence
    int v;
    endsequence
   endpackage
    bit clk, a, b, c, d;
    int r1=2, r2=5;
    initial forever #10 clk=!clk;
##0 b;
generate option
if (g_i >= N)
end endgenerate  */
    property p1;
        ##0 b;
    a_p2: assert property(@ (posedge clk) $rose(a) |-> ##[2:5] b );
       bit va, vb;
      repeat(200) begin
        @(posedge clk);
        if (!randomize(va, vb)  with
        { va dist {1'b1:=1, 1'b0:=3};
          vb dist {1'b1:=1, 1'b0:=2};
       a <= va;
       b <= vb;
    $stop;
My requirment is this. But i am getting error
int width=10;
property abc;
@posedge clk
$rose(a)|=> $stable(a)[*width];
In reply to kolliparapavankumar:
You should have looked further into my package sva_delay_repeat_range_pkg
https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats
package sva_delay_repeat_range_pkg;
     // int d1, d2;
    // bit a, b, c=1'b1;
    // sequence q_s; a ##1 c; endsequence
    // sequence my_sequence; e ##1 d[->1]; endsequence
    // ******       DYNAMIC REPEAT q_s[*d1] **********
    // Application:  $rose(a)  |-> q_dynamic_repeat(q_s, d1) ##1 my_sequence;
    sequence q_dynamic_repeat(q_s, count);
        int v=count;
    endsequence
endpackage
    bit clk, a, b, c=1, w;
    int width=10;
 ap_repeat: assert property(@ (posedge clk)
            $rose(a)|=> q_dynamic_repeat($stable(a), width) );
    Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
Here q_s means is it $stable
Yes, an expression is a sequence of 1 cycle.
If the sequence is more than 1 cycle, you will need to define it in a sequence declaration.
sequence var_width;
    int cnt;
    (req,cnt = 0) //local variables needs to be initialized
    ##1 (req, cnt++)[*1:$]
    ##1 (!req && (cnt == width-1) );
     endsequence: var_width
  property chkr;
    @(posedge clk)
    $rose(req) |-> var_width;
This is from an LRM example.
have setup a tb here, use it for testing.
