HI
Need to write a assertion ::
1)Pulse 1 should be high for 10~100 clock cycles.
2)Pulse 2 Should be high within Pulse 1 for 1 clock cycle.Pulse 2 should occur only one time.
Please help on this.
In reply to syed taahir ahmed:
Restating your requirements:
- Following the rise of “a”, “a” should be stable for 10 to 100 cycles.
- “a” represents an envelope in which a single pulse “b” should occur once.
initial
ap_b_in_a: assert property(@ (posedge clk)
$rose(a)[->1] |-> a[*10:100] intersect b[->1] ##1 b==0[*1:$]);
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
Thanks Ben!!
Hi Ben,
Seems like the property not able to fail for the occurrence of pulse 2 twice in pulse 1, i replicated the scenario in Eda playground ,please have a look.
link:: Edit code - EDA Playground
The assertion reflects the requirements:
ref files : http://systemverilog.us/vf/pulses2c.sv
http://systemverilog.us/vf/pulses2c.png
// master_prop states that pulse1 extends between 10 and 100 cycles, and within that region,
// you have ONE occurrence of pulse2=1 and then pulse2==1 possibly being repeated 1 to $.
pulse1[*10:100] intersect( pulse2[->1] ##1 pulse2==0[*1:$])
// That property is ian intersection, thus, with pulse1==1 at all cycles within that range,
// once pulse2==1 and then pulse2=0, THAT intersection is complete and the assertion succeeds.
// All we asked here is that plse2 occurs within pulse1[*10:100] but not within pulse1[*100]
property master_prop;
@ (posedge clk)
disable iff (reset)
$rose(pulse1)[->1] |-> pulse1[*10:100] intersect( pulse2[->1] ##1 pulse2==0[*1:$]);
// Now, what you may be looking for is that pulse1 holds (true) for 100 cycels
// and within that period pulse2 is a single pulse.
property master_prop2;
@ (posedge clk)
disable iff (reset)
$rose(pulse1)[->1] |-> pulse1[*100] intersect( pulse2[->1] ##1 pulse2==0[*1000]);
// However, if you still want pulse1 to be the range 10:100, you could add another assertion
// that once pulse1 occurrs, there should s single pulse2 until pulse1 falls.
ap_continue: assert property(@ (posedge clk) $rose(pulse1)[->1] |->
$fell(pulse1)[->1] intersect(pulse2[->1] ##1 pulse2==0[*1:$]));
Assertions can be tricky! That is why you need to test the complex ones and really understand the meaning behind the syntax.
Thanks Ben for detailed reply, I’ll get this one executed.
How about this?
property p1;
$rose(Pulse1) |-> Pulse2[=1] within Pulse1[*10:100];
In reply to devil47:
First off, let me correct some errors in my response:
- The following in INCORRECT
rose(pulse1)[->1] |-> pulse1[*10:100] intersect( pulse2[->1] ##1 pulse2==0[*1:]); // BAD
rose(pulse1) |-> pulse1[*10:100] intersect( pulse2[->1] ##1 pulse2==0[*0:]); // OK
$rose(pulse1) |-> pulse1[*10:100] intersect( pulse2[=1] ); // OK - Comments
$rose(pulse1)[->1] should be written as rose(pulse1) becuse the goto operator is meaningless here. b[->1] is equivalent to !b[*0:] ##1 b, thus causing unnecessary attempts. - b[=m] is equivalent to ( b [->m] ##1 !b [*0:$]
On your comments:
// You suggest
// Note:
seq1 within seq2) is equivalent to: ((1[*0:$] ##1 seq1 ##1 1[*0:$]) intersect seq2 )
// Thus, your suggestion is equivalent to
$rose(Pulse1) |-> (1[*0:$] ##1 Pulse2[=1] ##1 1[*0:$]) intersect Pulse1[*10:100];
// That is also equivalent to
$rose(a) |->
a[*1:4] intersect( b[->1] ##1 b==0[*0:1000]) );
``` verilog
// Always tests your assertions
// The following model demonstrates that all 3 assertions are equivalent in simulation
timeunit 1ns/100ps;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk, a, b;
default clocking @(posedge clk);
endclocking
initial forever #10 clk=!clk;
$timeformat(-9, 1, "ns", 8);
$display("%t", $realtime);
ap_within: assert property(@ (posedge clk) $rose(a) |->
b[=1] within a[*1:4]);
ap_ab_eqv: assert property(@ (posedge clk) $rose(a) |->
(1[*0:$] ##1 b[=1] ##1 1[*0:$]) intersect a[*1:4]);
ap_ab1: assert property(@ (posedge clk)
$rose(a) |->
repeat(200) begin
@(posedge clk); ##1;
if (!randomize(a, b) with
{ a dist {1'b1:=5, 1'b0:=1};
b dist {1'b1:=1, 1'b0:=3};
}) `uvm_fatal("RAND", "This is a randomize error")
$stop;
