Assertion to check if signal toggles
There are 2 signals ‘a’ and ‘b’. I have to write an assertion to check if ‘b’ does not toggle for 50 cycles when the toggle of ‘a’ is encountered.
In reply to taestytart:
ap_b_Stable: assert property(@ (posedge clk) $rose(a) |->
                                       $stable{b) [*50] );
  3. Papers:
Hi, thank you for the answer. From what I understand, when a goes from 0 to 1, b stays stable for 50 cycles. Is it possible to use rose and fell for ‘a’ in the condition?
($rose(a) || $fell(a) |->$stable(b) [*50]);
Yes because ($rose(a) || $fell(a) is and expression, and that expression is a sequence of 1 cycle.
The use of the sequential or would be inappropriate here because
($rose(a) or $fell(a) |->$stable(b) [*50]); // DO NOT USE
// Because all terms of the OR in the antecedent need to be verified with its consequent
// Esentially, the following
($rose(a) or $fell(a) |->$stable(b) [*50]);  // is equivalent to
( ($rose(a) |->$stable(b) [*50]) and ($fell(a) |->$stable(b) [*50]);
// If you insist on using the "or", then use the first_match() with it.
 ap_ab: assert property(@ (posedge clk) first_match($rose(a) or $fell(a))
                                                       |-> $stable(b)[*50]);
There is a general recommendation by people on the 1800’2017 committee on assertions that one should avoid using the first_match()
Got it! Thank you
One more note on *($rose(a) or $fell(a) |->$stable(b) [50]);
One can correctly argue that in this case the first_match() is not needed because
one of the 2 threads is false. These threads are the $rose(a) |-> consequent and the othher $fell(a) |-> consequent.
However, that would not be the case if one of the or elements were a sequence. Also, the or slows down the simulator because it has to process the other thread.
I still recommend the use of the boolean || or operator.
For a better understanding of the SVA model, I strongly recommend that you read my paper
Understanding the SVA Engine,
Browse all content in Verification Academy: Articles, Cookbooks, Resources, Sessions, and Tracks
