Hello,
I have a scenario in which i have to verify the time taken to change a state from one value to another, say there is a 3 bit variable and i want to verify whether the time taken to change from 3’h0 to 3’h1 or 3’h0 to 3’h2 similarly any change of that variable is equal to a specific time. How to do that?
I tried by doing the following:
property calc_rate (int rate);
realtime current_time;
disable iff(a)
$changed(state) |-> ('1, current_time = $realtime) |-> $past($changed(state), 1) |-> (rate == ($realtime - current_time)*1000 );
endproperty: calc_rate
assert_rate:
assert property ( @(posedge CLK) calc_rate(Rate))
`uvm_info("ASSERT", "equal", UVM_HIGH)
else `uvm_error("ASSERT", "not equal")
This approach is not working, Can you please suggest me to do the other way?
user49
March 22, 2019, 6:26pm
2
In reply to PavanSP :
A generic comment: You have way too many implication operators ; use those wisely.
The following model and testbench works.
typedef enum {ST0, ST1, ST2} state_e;
timeunit 1ns; timeprecision 100ps;
bit clk, a, b;
state_e state;
realtime expected_time=60ns;
default clocking @(posedge clk);
endclocking
initial forever #10 clk=!clk;
property calc_rate (state_e sta, stb, int rate);
disable iff(a)
($changed(state) && state==sta, current_time = $realtime) |->
first_match(##[1:$] state==stb) ##0 ($realtime - current_time) == rate;
assert_rate: assert property ( @(posedge clk) calc_rate(ST1, ST2, expected_time))
bit va, vb;
state_e v_st;
repeat(200) begin
@(posedge clk);
if (!randomize(va, v_st) with
{ va dist {1'b1:=0, 1'b0:=3};
v_st dist {ST0:=1, ST1:=2, ST2 :=1};
a <= va;
state <= v_st;
$stop;
# UVM_ERROR .\time_state.sv(21) @ 5900: reporter [ASSERT] not equal
# UVM_ERROR .\time_state.sv(21) @ 7700: reporter [ASSERT] not equal
# UVM_INFO .\time_state.sv(20) @ 8500: reporter [ASSERT] equal
# UVM_ERROR .\time_state.sv(21) @ 9300: reporter [ASSERT] not equal
# UVM_INFO .\time_state.sv(20) @ 10500: reporter [ASSERT] equal
# UVM_ERROR .\time_state.sv(21) @ 12100: reporter [ASSERT] not equal
# UVM_ERROR .\time_state.sv(21) @ 13700: reporter [ASSERT] not equal
SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
SVA: Package for dynamic and range delays and repeats | Verification Academy
SVA in a UVM Class-based Environment
In reply to ben@SystemVerilog.us :
Thanks Ben, It is working!!
nnd
November 4, 2020, 7:38pm
4
Hi Ben,
disable iff(a)
In the above property instead of keeping track of specific states, will the property work if we use $changed in the first_match of the consequent statement?
user49
November 5, 2020, 12:50am
5
In reply to nnd :
Yes. ($changed(state) is a legal expression
