Assertion for ACK and REQ
Assertion has to be coded for the following scenario.
  1. once the req come on the posedge of the clock, the ack should occur within 10 to 20 clock cycles.
  2. second req should not occur until the ack for first request is completed.
Please let me know on this.
STA
In reply to syed taahir ahmed:
Add a variable “bit busy;”
Upon a successful req, call a function to set busy=1. At the conclusion of the assertion, pass or fail, reset the busy.
Write a 2nd assertion “not (req && busy);”
Given those guidelines, write the assertion.
Ben systemverilog.us
Hi Ben,
I couldn’t understand the second assertion part.
The req will be high for one clock and then ack should occur within 10 to 20 cycles. Req should not occur until the ack completed.
Ben,
I guess the following assertion would cover both the requirements :
property req_ack;
@(posedge refclk)
$rose(req) |=> (##[9:20] ack) intersect (!req throughout ack[->1]);
In reply to sjain12:
Good solution, I like it!
Thanks Jain for your reply,
In reply to manjutumn:
  1. The assertion would still fail if the request is not a single cycle pulse.
  1. second req should not occur until the ack for first request is completed.
You need to add another assertion to cover the needed cases. Edit the code below to meet your requirements. I am providing concepts here.
// on item 1) I don't quite understand it.  Do you mean
ap_no2req: assert property(
not(req[*2]);
// On item 2)
// Add a variable "bit busy;"
// Upon a successful req, call a function to set busy=1.
// At the conclusion of the assertion, pass or fail, reset the busy.
// Write a 2nd assertion "not (req && busy);"
/*second req should not occur until the ack for first request is completed.[/quote]
You need to add another assertion to cover the needed cases.   */
bit clk,req, ack, busy;
initial forever #10 clk=!clk;
function void setbusy(bit x);
    busy=x;
ap_set_busy: assert property(@ (posedge clk)
                             ($rose(req) && !busy, setbusy(1)) |-> ack[->1] ##0 (1, setbusy(0)))
else setbusy(0);
    ap_no_2nd_req_until_ack: assert property(@ (posedge clk)
            not(req && busy));
    bit va, vb;
    repeat(200) begin
        @(posedge clk);
        if (!randomize(req, ack)  with
                { req dist {1'b1:=1, 1'b0:=3};
                  ack dist {1'b1:=1, 1'b0:=5};
    $stop;
  3. Papers:
not(req[*2]);
// On item 2)
    busy=x;
else setbusy(0);
            not(req && busy));
    bit va, vb;
    repeat(200) begin
        @(posedge clk);
    $stop;
  3. Papers:
Hi @user49
Can you please this
property req_ack;
  @(posedge refclk)
By that, do you mean something like:
upon a new req, starting from the next cycle req==0 and ack==0 for 8 cycles.
following this sequence, req==0 until ack that shall occur with the next 12 cycles
 $rose(req) |=> !req && !ack[*1:8] ##1
                          (ack[->1] intersect !req[*12]) ;
I would write properties like the followings.
//          _ 1 3 3   10        20
// req : __| |_____   ____
//                     <---_--->
// ack :    _______   ____|
property req_ack;
  $rose(req) |-> !ack ##1 (!req&&!ack)[*9:19] ##1 $rose(ack);
or
property req_low_until_ack;
  $rose(req) |=> !req[*10:20] ##0 $rose(ack);
property ack_low;
  $rose(req) |-> !ack[*10];
Hi Ben,
I was wondering if @sjain12’s solution can be rewritten as
property req_ack;
  @(posedge refclk)
    $rose(req) |=> (##[9:20] ack) and  (!req throughout ack[->1]);
Looks good.
On a related topic, see my paper
The Traditional Req/Ack Handshake, It’s More Complicated Than You Think!
