Assertion Check
In reply to emin:
In this case, there is no difference because the sequence is one term.
Great. Thank you for clarifying!
But we see different behaviour here,
In reply to rkg_:
How did ap2_1’s first thread did pass even though there we have b deasserted? I thought that must fail as well at the same time as ap2 since you said there is no difference.
In reply to emin:
OOPs! I spoke too fast, my apologies, the two ARE different.
Humans make mistakes :)
|-> ##1 (b)[*2]);
##1 b ##1 b
|-> (##1 b)[*2]
(##1 b) ##1 (##1 b)
That makes sense :) Thank you Ben! I appreciate.
In reply to emin:
Hi Ben,
Property :-
// 1st requirement (fll_lock_assertion):- FLL LOCK is asserted on detecting two positive edges
// of FLL INC or FLL DEC only when (fll_sar_eoc == 1). and fll_inc or fll_dec anytime after (sar_eoc==1) but once any thing (posedge of dec or inc) comes second comes between 1 to 8 (since prog_unlock is 1 here) then only lock should asserted.
// and two positive edge of fll_inc or fll_dec (consecutive is not necessary )
//between 1 to 6 clock cycle of sampled_clk
Type - 1
property p_lock_condition_check_unlock_prog_01;
        int inc_count, dec_count;
 @(posedge sampled_monclk) disable iff (!i_en_fll)
   ( o_fll_sar_eoc == 1 && i_fll_unlock_prog == 2'b01, inc_count=0, dec_count=0 )   |=>
             (1, inc_count+= $rose(o_fll_inc),dec_count+= $rose(fll_dec))[*1:8] ##0
            o_fll_lock==(inc_count==2 || dec_count==2);
Problem 1 :-lock is asserted after 22 clk cycle of sample_monclk. and above assertion is not able to caught. (marked in purple)
Problem 2 :- assertion failing after de-assertion of lock. (marked in red )
problem 3:- Unexpected triggered (marked in blue colour)
waveform attached.
Type -2 :
      ( (o_fll_sar_eoc == 1) && i_fll_unlock_prog == 2'b01 )   |->
            ##1 (($rose(o_fll_inc)[=2] or $rose(fll_dec)[=2]) intersect 1'b1[*1:8])
            ##0 o_fll_lock;
Problem -1 :- Assertion triggered but it start checking fll_inc or fll_dec right after the sar_eoc assertion till the 1 to 8 clock cycle of sample clk (instead it should wait and check fll_inc or fll_dec anytime after (sar_eoc==1) but once any thing (two posedge of dec or inc whoever come early ) between 1 to 8 of sample_monclk (since prog_unlock is 1 here) then only lock should asserted.[/b])
Waveform :-
do you see any issue ?
In reply to rkg_:
  • Looking at the waveforms, I see the antecedent being true for many cycles.
    ( o_fll_sar_eoc == 1 && i_fll_unlock_prog == 2’b01, inc_count=0, dec_count=0 )
    That creates multiple successful attempts, and each attempt triggers its own consequent thread that is independent of other threads. That can provide unexpected failures.
    See my paper - Understanding the SVA Engine.
    Verification Horizons - July 2020 | Verification Academy
    Try ($rose(o_fll_sar_eoc == 1) && i_fll_unlock_prog == 2’b01[/b], inc_count=0, dec_count=0 )
  • It is very difficult for someone (me included) to debug an assertion without understanding the complete image. My best advice is to run your assertion in a small testbench environment with the simulation tool in a debug mode. In that mode, you can view the threads and the local variables and understand why the tool is telling of a pass or failure. The tool (if correct, most likely so) will do what SVA expresses, not what you wish. Thus you need to understand why SVA is behaving this way.
  • Assertion never got triggered Check your testbench. Test your assertions separately in a small testbench.
  3. Papers:
Hi Ben,
Thanks for suggestion and i am totally agree with you.
Just one doubt on below assertion
            ##0 o_fll_lock;
** intersect 1’b1[*1:8] , will it start matching just after sar_eoc==1. is it correct understanding ?
** if yes, how to put condition so that it should only match after first posedge of fll_inc and fll_dec (anytime after sar_eoc==1)
In reply to rkg_:
            ##0 o_fll_lock;
// Rearranging the ()s
      antecedent |->
         ##1 ( (a_sequence or b_sequence) intersect 1'b1[*1:8]
         ##0 o_fll_lock;
// Thus, in
// the following two threads start at the same cycle
($rose(o_fll_inc)[=2] or $rose(fll_dec)[=2]) // One thread
1'b1[*1:8]                                   // a parallel thread
NO, sar_eoc==1 is in the antecedent. As mentioned above, the intersect starts after the ##1 at
Ben
Hi Ben ,
I have enabled the debug mode and i have few observation.
NO,$rose (sar_eoc) modified is in the antecedent. As mentioned above, the intersect starts after the ##1 at
($rose(o_fll_inc)[=2] or $rose(fll_dec)[=2]) → one thread start just after 1 clock cycle on detection of posedge of sar_eoc and it will run based on intersect 1’b1**[1:8]* here for 8 clock cycle , (if i change to 20 thread will finish at 20 clock cycle ).
case: 2 And one place even, there is no toggle in inc and dec, it has triggered .
*it seems, what i asked question looking right here "intersect 1’b1[1:8] , will it start matching just after sar_eoc==1" (in my case )
I guess it is not taking care $rose of (($rose(o_fll_inc)[=2] or $rose(fll_dec)[=2])
thus it is triggering case 2 (my assumption )
And from above comment : (a[=3] ##1 b; //3 non consecutive/consecutive a and then b anytime after last a ) we have used [=] operator so if anytime inc or dec goes high 2 times continuously it will start intersect which is happening in my case 2 (i guess).
I have attached the waveform :
if you can suggest changes , for after detection of posedge of sar_eoc , if ($rose(o_fll_inc)[=2] or $rose(fll_dec)[=2] (gap between two posedge of non- consecutive of inc or dec should be 8 sampled_monclk ) lock should asserted.
And in the same way
property p_lock_condition_check_unlock_prog_00;
   ( $rose (o_fll_sar_eoc ) && i_fll_unlock_prog == 2'b00, inc_count=0, dec_count=0)   |->
         **##1  ((inc_count==1 ||dec_count==1 ), inc_count+= $rose(o_fll_inc),dec_count+= $rose(fll_dec),$display("\t **time=%t inc_count**= %d, dec_count ",$time,inc_count,dec_count))**[*1:6] ##0
            o_fll_lock===(inc_count==2 || dec_count==2);
** inc_count and dec_count is always zero in my log even i can see the posedge of fll_inc and dec in my simulation (Seems $rose it is not taking)
In reply to rkg_:
I am having trouble deciphering your question.
I modeled your code using the variables a, b, c
http://systemverilog.us/vf/may7b.sv
Below is the insertion of the code and images.
Your code looks ok
What is the issue?
// DO you want this?
            ##0 o_fll_lock;
// OR this "intersect 1'b1[*1:8] , will it start matching just after sar_eoc==1"
            ##0 o_fll_lock;
I suggest that you play with my code, and add debugging features.
You may also want to rephrase your requirements in English.
    timeunit 1ns;  timeprecision 100ps;
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    bit clk, a, b, c, frame;
    event start, one, two, isct0, endc;
    /* ( (o_fll_sar_eoc == 1) && i_fll_unlock_prog == 2'b01 )   |->
            ##0 o_fll_lock; */
    function automatic void gen_e(int i);
        if(i==0) -> start;
        if(i==0)  frame = 1'b0;
        if(i==1) -> one;
        if(i==2) ->  two;
        if(i==3) ->  isct0;
        if(i==3) frame = 1'b1;
        if(i==4) begin frame = 1'b0; ->  endc; end
    always @(posedge clk) begin
       ap_test: assert property(@ (posedge clk)  ($rose(a),gen_e(0)) |->
        ##1 (1, gen_e(1)) ##0 ( ($rose(b)[=2], gen_e(2)) intersect
            (1,  gen_e(3))  ##0 1 [*1:8]  )
        ##0 (c, gen_e(4))) else  frame <= 1'b0;
       repeat(15) @(posedge clk) ; // separate threads for analysis
      repeat (200) begin
        @(posedge clk);  #2;
        if (!randomize(a, b, c) with {
          a dist {1'b1 := 1, 1'b0 := 4};
          b dist {1'b1 := 1, 1'b0 := 1};
          c dist {1'b1 := 1, 1'b0 := 1};
          `uvm_error("MYERR", "This is a randomize error");
      $finish;
  3. Papers:
Hi Ben,
As you asked,
What is the issue?
// DO you want this?   ---> **i want this**
            ##0 o_fll_lock;
            ##0 o_fll_lock;
http://systemverilog.us/vf/your_screen.png → In this snippet,(at your green arrow marker ) why is assertion is getting triggered since I do not see two non-consecutive inc or dec.
I am writing assertion to check lock is happening only if two posedge of inc or dec (means only two non consecutive ) and gap between two posedge inc or dec is 1 to 8 cycle of sample_monclk.
In reply to rkg_:
I updated the snippet http://systemverilog.us/vf/intersect8.png
  • The ( (o_fll_sar_eoc == 1) && i_fll_unlock_prog == 2’b01 ) is the antecedent that matches (In the referred snippet) at my RED arrow marker. This is the START. Technically, this is called a successful attempt.
  • With a matched antecedent the consequent is immediately evaluated because of the Overlapped implication operator |->
  • The first thing in the antecedent is the ##1. Thus, one cycle after the start you start two concurrent threads that are ORed. This is a sequence OR.
  1. (($rose(o_fll_inc)[=2]
  2. $rose(fll_dec)[=2])
    The result of that ORed sequence must intersect the sequence *1’b1[1:8]
The assertion is working as defined. See my example in my previous reply where instead of your variables and your sequences, I use a simplified version of the same form with the variables a, b, c.
Thanks for detailed description.
Just last doubt regarding this assertion.
How to modify this assertion so that intersect event(isct0) should only active after the first posedge of inc or dec.
Specification says : lock should only asserted only when (eoc ==1) and two non consecutive posedge of inc or dec anytime after when (eoc =1) and length or gap between two non cosecutive posedge of inc or dec should be 1 to 8 clock cycle of sampled monclk. if length is more then 8 and if lock get asserted it should fail.
       (($rose(o_fll_sar_eoc) && i_fll_unlock_prog == 2'b01 ),gen_e(0))   |->
           ##1(1, gen_e(1)) ##0 ((($rose(o_fll_inc)[=2],gen_e(2)) or ($rose(fll_dec)[=2],gen_e(2))) intersect (1,  gen_e(3))  ##0 1[*1:8]) ##0 (o_fll_lock,gen_e(4));
waveform :
In reply to rkg_:
By now you have a good understanding of the concepts to address your requirements.
On the intersect sequence, define that length instead of 1 to 8 to something like
// that intersect event(isct0) should only active after the first posedge of inc or dec.
( (inc[->1] or dec[->1]]) ##1 1'b1[*1:8])
Again, by now you should understand this solution and the approach concepts.
The detailed implementation of the assertion is up to you.
Ben systemverilog.us
Hi Ben ,
Thank you so much for you help and letting me know about how to debug the assertion using Event .
The Event trigger was very useful to see what is happing in simulation.
In reply to rkg_:
Hi Ben,
Just little modification required in below property . i have tried many attemp but could not able to get how to restart the searching again.
           ##1(1, gen_e(1)) ##0 ((($rose(o_fll_inc)[=2],gen_e(2)) or ($rose(fll_dec)[=2],gen_e(2))) intersect ( (($rose(o_fll_inc)[=2],gen_e(3)) or ($rose (fll_dec)[=2],gen_e(4))) ##1(1, gen_e(6)) ##0 (1'b1[*1:8],gen_e(5))) )##0 (o_fll_lock,gen_e(5));
Last time i have told
But little modification on above property :
lock should only asserted only when (eoc ==1) and two non consecutive posedge of inc or dec anytime after when (eoc =1) and if length or gap between two non concscutive posedge of inc or dec crosses the the 8 (1st red arrow )sample_monclk it will again start (2nd Red arrow) searching the two non consecutive posedge of inc or dec between 1 to 8 clock cycle of sampled monclk until sar_eoc == 0.[/i]
waveform
In reply to rkg_:
Something like the following
let n=some_int; // like 10
    antecedent |-> ##1
       (sequence1 intersect sequence2) [*1:n] Boolean_expr
    // <--------- sequence ---------->
    (($rose(o_fll_sar_eoc) && i_fll_unlock_prog == 2'b01 ),gen_e(0))   |-> ##1
     ( (1, gen_e(1)) ##0 ((($rose(o_fll_inc)[=2],gen_e(2)) or ($rose(fll_dec)[=2],gen_e(2))) intersect
     ) [*1:$] ##0 (o_fll_lock,gen_e(5)); // could limit the repeat to something like [*1:5]
