Achieving Dynamic delays in SVA using subroutine
Hi ,
I was trying alternative to Dynamic delay : sq_1 |-> ##d1 sq2 using subroutine call ( so that I can use SV procedural constructs ) : edalink
However I observe the o/p differs across simulators . Two tools throw assertion failure at T:5 whereas
3rd tool throws compilation error : xmvlog: *E,SFLNOS (testbench.sv,34|50): Delays or wait statements in match item task calls are not supported.
[Q1] Is the code legal ? i.e Can the task block ?
[Q2] If the code is legal then why does the assertion fail at T:5 ? I expected ‘b’ to be evaluated only after task completes at T:45
In reply to MICRO_91:
[Ben]The code is legal in that it will compile and should simulate.
We do not address tools in this forum. Note that not every feature of SV is
necessarily supported by vendors.
[Ben] Tasks do NOT block; it’s more like fire and forget.
Thus, @( posedge clk ) a |-> ( 1, dynamic_delay2( val ) ) ##0 b ;
is functionally (but not per 1800) equivalent in this case to :
@( posedge clk ) a |-> (1 ##0 b) and (1, dynamic_delay2( val ));
I use the “and” to demonstrate the concept that the task call has nothing to do
with the (1 ##0 b). The task fires and does its thing until completion.
If you want to use the task approach, then complete the consequent within the task,
as shown in the code below.
Dynamic Delay(2) - EDA Playground // code
EPWave Waveform Viewer // wave
task automatic dynamic_delay2( int cnt );
    $display("Task called at T:%0t with i/p arg == %0d",$time,cnt);
    if( cnt > 0 ) begin
       repeat( cnt ) @( posedge clk );
      am_b: assert(b) pass=pass+1; else  fail=fail+1;
       $display("Task completes at T:%0t",$time);
    property prop;
      @( posedge clk )  a  |->  ( 1, dynamic_delay2( val ) ); //  ##0 b ;
  assert property ( prop ) pass=pass+8; // $display("T:%0t Assertion PASS" , $time);
                     else  fail=fail+8; // $display("T:%0t Assertion FAILS" , $time);
See my paper Understanding the SVA Engine Using the Fork-Join Model
Using a model, the paper addresses important concepts about attempts and threads. Emphasizes the total independence of attempts.
BTW, your original code, slightly modified to show the assertion results in the waveform is available at:
Dynamic Delay(1) - EDA Playground // code
// Original code with BAD use of tasks
task dynamic_delay2( int cnt );
    if( cnt > 0 ) begin
    property prop;
  assert property ( prop ) pass=pass+1; // $display("T:%0t Assertion PASS" , $time);
                     else  fail=fail+1; // $display("T:%0t Assertion FAILS" , $time);
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
Thanks Ben for the detailed explanation .
So b is evaluated ONLY once at T:5 i.e same time as consequent is evaluated .It isn’t evaluated again after task completes
A few questions regarding :
I was referring section 16.11 of the LRM which says :
All subroutine calls attached to a sequence are executed at every end point of the sequence. For each end point, the attached calls are executed in the order they appear in the list. Assertion evaluation does not wait on or receive data back from any attached subroutine. The subroutines are scheduled in the Reactive region,like an action block.
This means that although property expression ( variables ‘a’, ‘b’ ) is evaluated in observed region the task dynamic_delay2 gets executed in Reactive region ?
So ‘b’ would be evaluated in Observed region at T:5 before $display within the task which executes in Reactive region at T:5 .
(1) As both $display in PASS/FAIL action block as well as $display in task dynamic_delay2 execute in Reactive region , is there a pre-defined order of execution b/w the 2 $displays?
(2) Also what does the following mean : “All subroutine calls attached to a sequence are executed at every end point of the sequence.” ?
[Ben] Correct. The way I see it, The subroutines (i.e., tasks) are scheduled in the Reactive region, like an action block. There is no blocking to the sequence within the assertion.
If you have a function that return a value, e.g., (seq, v=f(v)), the f(v) is considered
an expression and is evaluated in the Observed Region. If the function is void,
e.g., (seq, f_void(v) then f_void is executed in the Reactive Region. The task or void function
once started can complete after the assertion that called is done.
Am verifying this statement with a colleague
[Ben] Youre referring to this code:
..@( posedge clk )  a  |->  ( 1, dynamic_delay2( val ) ) ##0 b ;
Yes. Also, b may have schaged value if it was updated in the NBA region.
You should use $sampled(cnt) instead of cnt.
Its probably a tool thing, but my guess is that there is queue
That is true. for example: sequence s; a ##1 b; endsequence
…(a ##1 b, v=1) // v==1 after a ##1 bl the end point o that sequence
…(s, v=1) // v==1 at the end point of s
Thanks Ben for pointing the following :
Hence in your solution to the original question at the top :
    if( cnt > 0 ) begin
// Changed to $sampled( b ) so that pre-poned value is used incase b is updated in NBA region
       am_b: assert( $sampled(b) ) $display("Assertion Pass");
         else  $display("Assertion Fails");
    property prop;
    assert property ( prop ); // PASS/FAIL within task
…am_b: assert( $sampled(b) );
Not necessarily. If you use good RTL guidelines. Specifically,
  1. Every register is updated with the nonblocking assignment
    (e.g., always @(posedge clk) b <= q; )
  2. All comb logic has its source from those registers updated in the NBA region.
    (e.g., always_comb m=!b; )
    If the immediate assertion follows the @(posedge clk), like in your example) then
    the assertion occurs in the 1st iteration of the Active region; thus “b” has the same value as its sampled value. Example:
 always_comb  m=!b; // m is updated in the 2nd iteration of the Active region
                    // After b's updated in the NBA region
 always @(posedge clk) begin
   b <= q;
   am_m: assert(m);
HOWEVER, if I wrote something like:
…@( posedge clk ) a |-> c ##cnt ##0 b ; // illegal if cnt is dynamic
and I wanted to use a task that computes this consequent then I would need
to use the $sampled(c) since the task is executed in the Reactive region.
…@( posedge clk ) a |-> ( 1, dynamic_delay2( val ) );
// removed the debugging stuff for simplicity
// @( posedge clk )  a  |-> c ##cnt ##0 b ;
    am_cb: assert($sampled(c));
    if($sampled(c) && cnt > 0 ) begin
    // NO NEED to Changed b to $sampled( b )
       am_b: assert(b); // b's value == $sampled(b)
    property prop;
    assert property ( prop ); // PASSes if a==1, it never fails
NOTE: Formal input args passed by value receive sampled actual arguments.
https://rb.gy/f3zhh
Thus, for …@( posedge clk ) a |-> c ##cnt ##0 b ; // illegal if cnt is dynamic
and I wanted to use a task that computes this consequent then I could pass the argument c to the task.
task automatic dynamic_delay2( int cnt, bit c );
    am_cb: assert(c); // the actual is the sampled value
    property prop;
      @( posedge clk )  a  |->  ( 1, dynamic_delay2( val, c) );
    assert property ( prop ); // PASSes if a==1, it never failsc
Ben
Hi Ben .
  bit clk , a ;
  bit [2:0] b , c ;
  always #5 clk = !clk ;
  int val = 4 ;
  always @( posedge clk ) b <= b + 1 ;
  always @( posedge clk ) c <= c + 1 ;
 task automatic dynamic_delay2( int cnt );  // Executes in Reactive Region
    // Trying Sequence : @( posedge clk )  a  |-> c ##dyn_delay b ;
    $display(" Within task b == %0d",b); // I observe value updated in NBA region
    $display(" Within task c == %0d",c); // I observe value updated in NBA region
    am_cb: assert( $sampled(c) );
      $display(" Delay completes at T:%0t",$time);
// For below immediate assertion : Some tools sample NBA updated value while some sample Pre-poned
     am_b: assert( b == 4 )  // Discrepancy  here ?
           $display(" PASS with b == %0d",b);
      else $display(" FAIL with b == %0d",b);
  property prop;
Verilog tells us that $display executes in Active region
[1] When does the $displays within the task execute ? Is it in Reactive region OR in Active region ( via loopback from Re-NBA to Active Region )
[ NOTE : There is No loopback directly from Reactive to Active Region ]
[2] It seems that some tools use updated value of b : edalink
 Hence to avoid the tool discrepancy I feel it's better to use $sampled( b ) instead .
 Within the task when we write : **repeat( cnt ) @( posedge clk );**
@(posedge clk) executes in **re-entrant Active region ( via loopback from Re-NBA to Active Region )**
( However I believe the NBA assignment to b would execute before the loopback to Active region )
When we write the next statement as : assert(b);
(a) Are we still in Active Region ? i.e Non-blocking update to ‘b’ hasn’t occurred yet.
(b) For some tool it seems that since the subroutine execute in Reactive region , the updated value of ‘b’ is sampled ( i.e immediate assertion executes in Reactive region ).
Although @( posedge clk ) unblocks in re-entrant Active region , the NBA update to b is already done
[3] In your code : edacode
As always_comb executes at T:0 we end up using the value updated at T:0 for m within the immediate assertion at the 1st clock edge.
 Hence there is No discrepancy in output across tools in this case as the immediate assertion executes in 1st iteration of Active region prior to NBA update ( unlike the immediate assertion called in subroutine which executes in Reactive region post NBA region update )
With @( posedge clk ) a |-> ( 1, dynamic_delay2( val ) );
the task is started in the Reactive region.
then task automatic dynamic_delay2( int cnt ); // Executes in Reactive Region
b== current value in current region.
I would think that since $display is a statement, it executes when it is seen.
This is not an assertion. You would need a $sampled(b) unless the assertion passes b
as an actual argument to the task.
Hence to avoid the tool discrepancy I feel it’s better to use $sampled( b ) instead .
I didn’t analyze that code, but it might be a good discipline to use the $sampled.
Within the task when we write : repeat( cnt ) @( posedge clk );
@(posedge clk) executes in re-entrant Active region ( via loopback from Re-NBA to Active Region )
Yes. You have
     am_b: assert( b == 4 );
The tool is sensitive events. When an event occurs, you have regions for that even:
Active, NBA, Observed, Reactive, etc…
Thus, at the least repeat @( posedge clk ); you are now in the Active region.
am_b: assert( b == 4 ); // executes immediately. b has not changed yet, as you stated.
If I had the following
 ... @( posedge clk )  a  |->  ( 1, dynamic_delay2( val ) );
// **** am_cb assertion executes in the Reactive region, since it is upon entry
// and since immediate assertions executes in the place they are seen
// *** am_b executes in the Active region since @( posedge clk ) is the event
// that causes the simulator to enter the various regions, with Active being the 1st one.
Looks correct.
Ben
Thanks Ben .
So although task gets called in Reactive region of time:5 , @(posedge clk) blocks at t:5
It’s unblocked in Active region of T:15,25,35,45 ( due to repeat( 4 ) @(posedge clk); )
As a result we are currently in Active region at T:45 , immediate assertion : am_b: assert( b == 4 ) , executes in Active region of T:45 .
NBA region is yet to occur at this point .
you are correct.
Hopefully, these regions should be transparent in thesense that a user should not have to worry about regions. Just follow good coding styles.
always #(posedge clk) a=b; // BAD STYLE
always #(posedge clk) a<=b; // Good style
always_comb c=!a; // can execute in Activ region if a changes in same time
                  // event @(posedge clk)
 initial forever #1 clk = !clk ;
always #(posedge clk) am_c: assert(c); // an immediate asn in always
// in tb
#2 a=1; // same time as @(posedge clk)
// can cause issues in am_c assertion
#2 a=0;
@(posedge clk) a <=1; //  Good style.
// Make assignments to signals nonblocking
