APB READ_TRANSFER
 Presently I'm working on apb protocol, for apb read transfer(PSEL=1,PENABLE=1,PWRITE=0),
   first i write the data into a memory(using apb write_transfer),and i'm trying to do is read the data from memory(using apb read_transfer)
     but there is error in my uvm code for read transfer ,please can you check once
   https://www.edaplayground.com/x/5p5f
Prawin
In reply to PJ:
What type of errors are you facing? There are some obvious compilation errors in that code. Minor errors like “use of = instead of ==” or “missing semi-colon” and many more. What is the source of that code?
In reply to PJ:
Your Problem is here:
penable=rhs_.penable &&
it has to be
penable == rhs_.penable &&
as you did with all the other data fields.
Please observe the waveform, it is perfect with the write transfer,but error in read transfer
https://www.edaplayground.com/w/x/2KH
and
Scoreboard not working…
can u pls tell in which class this mistake is creating
In reply to vlsique:
It seems you fixed the code in the meantime. Because the old version did not compile.
It was in the seq_item definition.
In reply to PJ:
EPWave Waveform Viewer
and
Your sequence Body Task looks a Little bit strange.
  task body();
     //Create 10 random APB read/write transaction and send to driver
    rw_trans = apb_rw::type_id::create("rw_trans");
      //apb_rw::type_id::create(.name("rw_trans"),.contxt(get_full_name()));
    for(int i=0;i<5;i++) begin
       start_item(rw_trans);
       //assert (rw_trans.randomize());
      assert(rw_trans.randomize() with { addr==32'h6523_1221;data == 32'h1021_2321;apb_cmd == 1'b0;});
       finish_item(rw_trans);
      assert(rw_trans.randomize() with { addr==32'h6523_1221;data == 32'h1021_2321;apb_cmd == 1'b1;});
      assert(rw_trans.randomize() with { addr==32'h6526_1551;data == 32'h5555_0202;apb_cmd == 1'b0;});
      assert(rw_trans.randomize() with { addr==32'h6526_1551;data == 32'h5555_0202;apb_cmd == 1'b1;});
Could you please explain which apb_cmd is RD and which is WR. The RD needs only the command and the address, but no data in the sequence.
This is my Driver class… so apb_cmd =1 is RD and,= 0 WR
case (tr.apb_cmd)
1’b1: drive_read(tr.addr, tr.data);
1’b0: drive_write(tr.addr, tr.data);
endcase
i changed little bit of code, but now it is working fine. without scoreboard
In reply to PJ:
case (tr.apb_cmd)
endcase
can u pls share urs changed code
before change the code the uvm sequence like below ,i randomize penable,psel,pwrite directly here…
typedef enum {READ, WRITE} kind_e;
rand bit [31:0] addr; //Address
rand logic [31:0] data; //Data - For write or read response
rand logic penable;
rand logic psel;
rand logic pwrite;
rand kind_e apb_cmd;
so the sequence_item was :-
assert(rw_trans.randomize() with { addr==32’h6523_1221;data == 32’h1021_2321;apb_cmd == 1’b0;penable==1’b1;psel==1’b1;pwrite==1’b1});
but now,
i’m directly hard coded the psel,pwrite,penable values in uvm_driver only
case (tr.apb_cmd)
endcase
//Handshake DONE back to sequencer
seq_item_port.item_done();
endtask: run_phase
virtual protected task drive_write(input bit [31:0] addr,
input bit [31:0] data);
  this.vif.master_cb.paddr   <= addr;
 @(this.vif.master_cb);
  this.vif.master_cb.pwdata  <= data;
 this.vif.master_cb.psel    <= '1;
 this.vif.master_cb.penable <= '0;
 this.vif.master_cb.pwrite  <= '1;
k…
In reply to PJ:
I don’t understand why you have psel, pwrite and penable in your sequence item. I believe it does not make any sense to have them there. There is no need to randomize these items. They are simple control signals for your bus protocol.
yes chr_sue, that’s what i changed the code
In reply to PJ:
In waveform transfers of apb protocol working fine,but there is a mistake in scoreboard expected and actual values.
thanks,
pj
In reply to PJ:
In reply to PJ:
apb_with_sb - EDA Playground
thanks,
pj
why is scoreboard giving error ,i m not getting the solution ,can anyone pls help
You should publish the EDAplayground page …
sorry for delay.
you can proceed now.
pj
In reply to PJ:
Your environment looks a little bit like quick & dirty. There are a few weaknesses:
(1) the ADDR_WIDTH is not consistent (8/32 bit)
(2) you are dealing in some components with the clocking block in others not
(3) if you want to compare x-values (undefined) you have to use the case equality (===). Changing this generates only passes.
I did not investigate where the x-values are coming from and if they are correct.
am getting zero when fifo rd operation,
In reply to PJ:
I had a closer look to your code. You are still doing strange things:
(1) in the driver you have on the left-hand side in the run_task the transaction object.
(2) in the monitor you are assigning the re in the same clock as the value from the vif.d_out to your transaction.
I do not know your protocol, but I believe there is more than 1 clock cycle in between. The d_out in the wave forms is always ‘x’.
In reply to PJ:
I was now looking in more detail.
You are reading from your uninitialized memory. This is really not useful, because it returns only x on your interface.
And I modified your monitor to:
    sequence_item transaction;
    transaction = sequence_item::type_id::create("transaction");
  @ (posedge vif.clk);
  transaction.data_in = vif.din;
  transaction.wr_en = vif.wr_en;
  transaction.rd_en  = vif.rd_en;
  //transaction.data_ram = vif.mem;
  transaction.data_out = vif.dout;
  //$display("ram=%h",vif.mem);
  item_collected_port.write(transaction);
 `uvm_info("FIFO_MONITOR", $psprintf("Wrote transaction %s",transaction.convert2string()), UVM_LOW);
  endtask:run_phase
See the additional clockedge befor vif.dout will be stored.
