APB READ_TRANSFER
In reply to PJ:
I had a closer look to your code. You are still doing strange things:
(1) in the driver you have on the left-hand side in the run_task the transaction object.
(2) in the monitor you are assigning the re in the same clock as the value from the vif.d_out to your transaction.
I do not know your protocol, but I believe there is more than 1 clock cycle in between. The d_out in the wave forms is always ‘x’.
