Hi
How can I do xor in assertion property?
like-
property checker(clk,enable,a,b,idx);
@(posedge clk)
(enable) |-> a[idx^b] === b;
endproperty:checker
it’s seem it do idx power b …
Hi
like-
@(posedge clk)
endproperty:checker
In reply to Junior:
You are using the correct operator (^) for XOR. The power operator is (******)
In reply to Junior:
working as expected for me
module test();
bit clk;
bit en;
bit [3:0] a[8];
bit [3:0] b, exp_b[8];
bit [2:0] idx, idx_xor;
forever #5 clk = !clk;
assign idx_xor = idx^b;
a['b000^'b000] = 'b000; //a[0]=0
a['b001^'b010] = 'b010; //a[1]=2
a['b011^'b001] = 'b001; //a[2]=1
a['b100^'b011] = 'b011; //a[7]=3
// a['b101^'b010] = 'b010; //a[7]=2
//a['b000^'b000] = 'b000; //a[0]=0
@(posedge clk);
en <= 1;
idx <= 'b000;
b <= 'b000;
//a['b001^'b010] = 'b010; //a[1]=2
repeat(2)@(posedge clk);
idx <= 'b001;
b <= 'b010;
//a['b011^'b001] = 'b001; //a[2]=1
idx <= 'b011;
b <= 'b001;
//Assertion failure expected
idx <= 'b011;
b <= 'b110;
$display("Assertion failure expected : idx='b011, b='b110");
//a['b100^'b011] = 'b011; //a[7]=3
idx <= 'b100;
b <= 'b011;
en <= 0;
#50 $finish;
ap: assert property(checker(clk,en,a,b,idx));
@(posedge clk)
(enable, $display("%t idx=0x%x, b=0x%x, a[idx^b]=0x%x",$time, $sampled(idx), $sampled(b), a[$sampled(idx)^$sampled(b)]))
|-> a[idx^b] == b;
endproperty:checker
OUTPUT:
15 idx=0x0, b=0x0, a[idx^b]=0x0
25 idx=0x0, b=0x0, a[idx^b]=0x0
35 idx=0x1, b=0x2, a[idx^b]=0x2
45 idx=0x1, b=0x2, a[idx^b]=0x2
55 idx=0x3, b=0x1, a[idx^b]=0x1
65 idx=0x3, b=0x1, a[idx^b]=0x1
75 idx=0x3, b=0x6, a[idx^b]=0x0
"testbench.sv", 53: test.ap: started at 75ns failed at 75ns
Offending '(a[(idx ^ b)] == b)'
85 idx=0x3, b=0x6, a[idx^b]=0x0
"testbench.sv", 53: test.ap: started at 85ns failed at 85ns
95 idx=0x4, b=0x3, a[idx^b]=0x3
105 idx=0x4, b=0x3, a[idx^b]=0x3
In reply to Alokpati:
Thanks guys for your help,
seem that the issue was different.
another query,
I have 1 property, that I assert to it multiply times,
and for some this working -
(A) |-> ## [0:3] ($past(sig_1) === sig_2);
and some didn’t have delay and this works fine -
(A) |-> ## [0:3] sig_1 === sig_2;
and my question is if there is can be some merge between the two?
cause I don’t want to do 2 assertions…
Thanks!!
In reply to Junior:
can you elaborate what is the exact scenario for which you want to write assertion?
I have a situation that between sig 1 & sig 2 there is a delay of 1 cycle.
and for itm this assertion is working well:
another scenario, is that the sig2 happened in the same cycle as sig 1
now want I want to do is to do 1 property to the 2 scenarios.
In reply to Junior:
(A) |-> ## [0:3] $past(sig_1) === sig_2 || sig_1 === sig_2;
Please start a new question with a new topic.
