Wire declaration inside systemverilog class is illegal. Please help explaining why is it illegal.
Thank you.
In reply to mannat:
wire is static, class is dynamic.
instantiate a class that contains wire makes no sense.
In reply to mannat:
Because This Is The Way.
Sorry for that abrupt response, but there is no good reason other than that’s the way the language has been set up since its inception. A wire represents a network of connections as well as a value. A wire does not store any values; it value is the resolution of all the drivers in the network. The network gets created at elaboration before simulation begins. The language has no provisions for modifying a network at runtime, except for maybe a force statement.
SystemVerilog has reduced the need for wires except for special cases where you need multiple drivers on the network. I guess that might be a good reason why there is no need to add wires to classes.
