Will forcing an assigned wire also force the assignee?
wire a;
wire b;
assign a = b;
Will
force a=1;
also force b to 1?
I ran this code:
 	wire a;
	wire b;
	assign a = b;
    force a = 1;
    #100;
    $display("a=%b", a);
    $display("b=%b", b);
The output is:
a=1
b=z
So I think the answer is no, it won’t force b to 1.
In reply to kjhhgt76:
A continuous assign statement is unidirectional. The flow of data is always from RHS to LHS of the assignment.
The same cannot be said about a port connection when both sides of the connection are nets.
  wire a=1;
  bot inst(.b(a));
      #1 $display("a: %b",a);
      force inst.b = 0;
      #5 $display("a: %b",a);
module bot(input wire b);
    #1 $display("b: %b",b);
    #5 $display("b: %b",b);
The wires a and b get collapsed into a single net.
The output of your code is
a: 1
b: 0
a: 0
b: 0
not
a: 1
b: 1
a: 0
b: 0
why?
THere are race conditions in my code between the two initial blocks. You get different results depending on which tool you try. Changing the first #1 to a #2 removes the races.
