Hi all,
I’ve implemented the shutdown_phase with some register reads in my test, but it occurs at 0ns, before the run_phase starts.
Which event is responsible for triggering shutdown_phase?
This is a code snippet from my test:
class setup_test extends reset_test;
// Sequences
init_dut_ahb_api_seq_lib ahb_m;
`uvm_component_utils(setup_test)
super.new(name,parent);
ahb_m = new("ahb_api_seq_lib");
super.build_phase(phase);
endfunction: build_phase
function void report_phase(uvm_phase phase);
super.report_phase(phase);
virtual task check_m_counters();
ahb_m.ahb_master_seqr = tb.virtual_sequencer.ahb_master_seqr;
ahb_m.ahb_reg_map = tb.regmap.bus_map;
ahb_m.ahb_reg_block = tb.regmap;
ahb_m.ahb_label = "m_ctrl__";
ahb_m.ahb_sm_file_label = "CFG_FILE_AHB_M";
ahb_m.check_overall_access();
virtual task pre_shutdown_phase(uvm_phase phase);
uvm_report_info( get_type_name(), "PRE_SHUTDOWN_PHASE", UVM_NONE);
check_m_counters();
This is my output
%% UVM_INFO @ 0.00 ns: uvm_test_top [tc_spahb_mi_001] PRE_SHUTDOWN_PHASE
