module asertion_ex;
bit clk=0;
bit a;
always #5 clk = ~clk; //clock generation
//generating 'a'
a=1;
#15 a=0; // not working
//#14 a=0; // is working
#10 a=1;
#10 a=0;
#10 a=1;
#10 a=0;
#10 a=1;
#10;
//assertion sequence
sequence seq_1;
@(posedge clk) a==1;
endsequence
//calling assert property
a_1: assert property(seq_1)
$display("success, time: %0t, a: %0d", $time, a);
$display("failed, time: %0t, a: %0d", $time, a);
initial
#1000;
$finish;
In reply to muku_383:
Issue isn’t with #15.
//1. assertion sample the value in the prepone region and use that value in deciding the outcome of the assertion
//2. Execution of the pass/fail code of concurrent assertions happen in the re-active region.
//In between 1 and 2, assignment of the variable a happens.
// so if you use the $sampled then it will display the value which was used for assertion evaluation.
$display("success, time: %0t, a: %0d", $time, $sampled(a));
$display("failed, time: %0t, a: %0d", $time, $sampled(a));
I suggest you to go through the SV Scheduling.
In reply to Rahulkumar:
sure sir, thank you
Need one more help sir,
i want to read random generated text file and send to driver using UVM.
- i have random generated signals as:- rq1: 2, rq2: 10, rq3: 22.
in sequence - open ran_gen.txt file
- read first string word from txt file and split into 3 part because, 3 signals are there and i need those 3 to send to driver.
- after split need to store into reg and then use `uvm_Send to send it to driver.
is it right step?
is it right step?
do you mean store into object (transaction class) when you say store into reg (4th point)?
if Yes then this approach looks fine to me.
