In reply to srirahulch95:
Time should be in number of clock cycles, not in ns.
Let max_cycles=20;
ap_max: assert property(
@(posedge clk) $rose(master_rise) |-> ##[1:max_cycles] $rose(slave_rise));
Ben systemverilog.us
Looks like his intention is to check if the delay between slave_rise and master_rise is equal to the expected duration.
In that case he should use ##[0:] instead of [*0:].
Below code should serve the intention.
property p_max_time(clk,master_rise,slave_rise,duration);
time start_time;
@(posedge clk) ($rose(master_rise),start_time = $realtime) |-> ##[1:$] $rose(slave_rise) ##0 (($realtime -start_time) == duration);
Regards,
Manju
https://www.linkedin.com/in/manjubhat/
