What is the advantage of using ##0 over |-> overlapping implication operator in SVA?
Hi, When i replace |-> with ##0 in my code i’m observing some change, but i’m interested in knowing what is the advantage of using ##0 over |->. can anyone help me with this
Thanks You
In reply to Amruthabmanigar:
(1) Implication operators ( |-> / |=> ) are illegal within a sequence body. So you will have to use ##0/##1 instead.
(2) Using ##N ( where N >= 0 ) enables the user to concatenate sequences.
In reply to MICRO_91:
Thanks for the Reply.
But is there any difference when we use these in the property. does using ##0 avoid vacuous success.
The ##n is a sequence operator, The |-> is a property operator.
a |-> b // if a==0 then the property is vacuous.
a ##0 v // if a==0 then the sequence is not a match,
I wrote many papers on SVA. I suggest that you read the on understanding the SVA engine.
You’ll also pick up more info on my other papers.
Ben@systemverilog.us
