Variable range in system verilog assertion property
Hi All,
I am trying to check the req and ack timing. Where the range needs to be varied.
property req_ack_timing;
@(posedge clk)
$rose(req) |-> ##[0:num_clks] $rose(ack);
endproperty : req_ack_timing
Here, the num_clks changes during the run time. While compiling this, I get non-constant expression used.
Is there a way to check an assertion of a signal in a range which can change during run time?
Madhukar
In reply to MadhukarN:
You need to create a local down counter:
https://verificationacademy.com/forums/systemverilog/assertion-check-signal-value-between-min-and-max-range#reply-60714
Since you are starting at 0, you could probably simplify it.
I just posted this package:
****SVA: Package for dynamic and range delays and repeats [/b]
https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats
  1. Verification Horizons - March 2018 Issue | Verification Academy
  2. http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
  3. “Using SVA for scoreboarding and TB designs”
    http://systemverilog.us/papers/sva4scoreboarding.pdf
  4. “Assertions Instead of FSMs/logic for Scoreboarding and Verification”
    October 2013 | Volume 9, Issue 3 | Verification Academy
  5. SVA in a UVM Class-based Environment
    FREE BOOK: Component Design by Example
    … A Step-by-Step Process Using VHDL with UART as Vehicle
    http://systemverilog.us/cmpts_free.pdf
