Need some help passing a string to hierarchical access
I am trying to access RTL signals in design, all RTL signal names are similar except for one number changes, for example, dut.csr.oport_p1.valid, dut.csr.oport_p2.valid, dut.csr.oport_p3.valid … This design is highly configurable, ports can be enabled and disabled using parameters. so, some times these registers are present, sometimes these are disabled. How can I access these signals?
I tried doing something like this, but it didn’t work
`define IPORT(n) dut.csr.oport_pn.valid
parameter P_NUMBER_INPUTS = 32;
parameter [P_NUMBER_INPUTS-1:0] P_INPUT_PORT_EN = 32’h1f01; // can be programmed to a different value from top
genvar p;
generate
for(p=0; p < P_NUMBER_INPUTS; p++) begin
if(P_INPUT_PORT_EN[P])begin
valid = `IPORT(p); I want it to be like this dut.csr.oport_p1.valid, .*p2.valid, .*p3.valid, .*p4.valid, .*p5.valid …instead it is getting expanded like this dut.csr.oport_pp.valid
I also tried this works but code becomes very lengthy so trying to find a better approach
if(p == 1) begin
valid = IPORT(1); end if(p == 2) begin valid = IPORT(2);
if(p == 3) begin
valid = `IPORT(3);
.// for ohter ports
Please recommend me a better way to access these signals.
