Variable clock generation in verilog using task
I have used following code to generate clock (whichever value i pass through task it will create that frequency), but the code only works if i use CLKSEL_global = clksel_local (line no. 23)(i.e. blocking assignment) but that creates delta delay.
 `timescale 1ns/1ps
module new(CLK,CLK_OUT);
input CLK;
output CLK_OUT;
and(CLK_OUT,1,CLK);
`timescale 1ns/1ps
module tb();
real CLKSEL_global;
reg clk;
reg CLK7;
wire clk_out;
new dut(clk,clk_out);
task task_CLOCK;
input real clksel_local;
CLKSEL_global = clksel_local;
 CLK7 = 0;
 forever begin
  #(500.0/CLKSEL_global) CLK7 = 1;
  #(500.0/CLKSEL_global) CLK7 = 0;
always @(CLK7) begin
   clk = CLK7;
task_CLOCK(340.0);
 #100 $finish ;
How do i generate variable clock without introducing delta delay ?? or is their other way than using a task
Thank you in advance
