Valid parentheses sequence
How can we generate valid parenthesis sequence using SystemVerilog constraints?
Example: If length is 6, all of these valid combinations must be generated ()()(), ((())), (())(), ()(())
In reply to akshataudpi:
This is a fun interview question
  class P;
    rand bit signed [1:0] parens[];
    function new;
      parens = new[6];
    constraint c {
      foreach(parens[i]){
        // 1 is open, -1 is close parenthesis
        parens[i] inside {1,-1};
        // can never have more close than open parenthesis in sequence
        parens.sum() with(item.index<=i? int'(item) : 0) >= 0;
      // number of open and close parenthesis must be equal
      parens.sum() with (int'(item)) == 0;
    function void print;
      foreach(parens[i]) if (parens[i] > 0)
        $write("(");
        $write(")");
      $display;
  P p=new;
      initial repeat(10) begin
    assert(p.randomize);
    p.print;
which constraint can be used to avoid such as )(, )))(((, ()))(( ?
In reply to VE:
Dave,
Why are you using int’(item) and not just item? TIA.
In reply to Verif Engg:
It’s not strictly necessary as it is already implicit because of the RHS 0 in the conditional expression, but being explicit never hurts and is a good habit to keep.
Could you please elaborate on how this is expanded into an equation? Isnt item.index is same as i?
Thanks.
In reply to sjain12:
They are not always the same. item.index is a nested iterator within i.
The constraint
    constraint c {
      foreach(parens[i]){
expands to
        parens.sum() with(item.index<=0? int'(item) : 0) >= 0;
        parens.sum() with(item.index<=1? int'(item) : 0) >= 0;
        parens.sum() with(item.index<=2? int'(item) : 0) >= 0;
        parens.sum() with(item.index<=3? int'(item) : 0) >= 0;
        parens.sum() with(item.index<=4? int'(item) : 0) >= 0;
        parens.sum() with(item.index<=5? int'(item) : 0) >= 0;
Then the first sum() when i = 0 expands to
(0<=0? int'(parens[0]) : 0) + // item.index = 0 item = parens[0]
(1<=0? int'(parens[1]) : 0) + // item.index = 1 item = parens[1]
(2<=0? int'(parens[2]) : 0) + // item.index = 2 item = parens[2]
(3<=0? int'(parens[3]) : 0) + // item.index = 3 item = parens[3]
(4<=0? int'(parens[4]) : 0) + // item.index = 4 item = parens[4]
(5<=0? int'(parens[5]) : 0)   // item.index = 5 item = parens[5]
which collapses down to
int'(parens[0]) + 0 + 0 + 0 + 0 + 0
So the entire set of constraint equations becomes
parens[0] >= 0; // i = 0
parens[0] + parens[1] >= 0; // i = 1
parens[0] + parens[1] + parens[2] >= 0; // i = 2
parens[0] + parens[1] + parens[2] + parens[3] >= 0; // i = 3
parens[0] + parens[1] + parens[2] + parens[3] + parens[4]>= 0; // i = 4
parens[0] + parens[1] + parens[2] + parens[3] + parens[4] + parens[5]>= 0; // i = 5
For clarity, I removed the cast to int’() around each element.
You have an amazing thought process!!
Thanks for sharing the knowledge.
There is other question similar to above , check whether the given parenthesis is valid or not . I have implemented below using stack concept .
module check_parentheses_stack;
  // Function to check if the parentheses sequence is valid using a stack
  function bit isValidParentheses(string seq);
    byte stack[$]; // dynamic queue as stack for '(' chars
    foreach (seq[i]) begin
      if (seq[i] == "(")
        stack.push_back(seq[i]); // push '(' onto stack
      else if (seq[i] == ")") begin
        if (stack.size() == 0)
          return 0; // No matching '(' for current ')'
          stack.pop_back(); // pop matched '('
    return (stack.size() == 0); // valid if stack empty at end
    string test_seq;
    test_seq = "(()())";
    $display("Sequence: %s is valid? %0b", test_seq, isValidParentheses(test_seq));
    test_seq = "(()))(";
    test_seq = "())()";
    $finish;
Hi @dave_59 , Is it not possible to simpify expression(
using simple function call inside constraints ? OR any other simple way ?
Modified your code as below but output is coming wrong . please help me
  class P;
    function new;
      parens = new[6];
    constraint c {
      foreach(parens[i]){
        check_prefix_sum(parens[i]) >= 0 ;
        $write("(");
        $write(")");
      $display;
    function int check_prefix_sum(bit signed [1:0] parens_a);
  int prefix_sum;
      foreach (parens_a[i]) begin
    prefix_sum = 0;
    for (int j = 0; j <= i; j++) begin
      prefix_sum += parens_a[j];
       return prefix_sum;
  P p=new;
    p.print;
