UVM vs SystemVerilog
What are the advantages of using UVM over SystemVerilog for verification?
UVM is a SystemVerilog class library explicitly designed to help you build modular reusable verification components and testbenches. It is an industry standard so you can acquire UVM IP from other sources and use them in your environment. If you don’t use UVM, you’ll have to build everything yourself from scratch.
In reply to tfitz:
Thanks…
