UVM monitor sees the inputs after 2 clock cycles
My driver code is as below for an up/down counter:
    super.run_phase (phase);
    // task to initialise the driver signals
    initialize();
    forever begin
      drive();
      seq_item_port.item_done();
    end //forever
  endtask : run_phase
task initialize();
  //default values
  counter_vif.load_counter <= 1'b0;
  counter_vif.count_value  <= 0;
  counter_vif.up_counter   <= 0;
endtask : initialize
virtual task drive();
  @(posedge counter_vif.clk);
    if (counter_vif.clk_en) begin
      counter_vif.count_value  <= req.count_value;
      counter_vif.load_counter <= req.load_counter;
      counter_vif.up_counter   <= req.up_counter;
     end //if
  req.print();
My monitor code is as below:
 forever begin
   @(posedge counter_vif.MONITOR.clk);
    if (counter_vif.MONITOR.clk_en && counter_vif.MONITOR.reset) begin
     seq_item_collected.count_value   = `MON_IF.count_value;
     seq_item_collected.load_counter  = `MON_IF.load_counter;
     seq_item_collected.up_counter    = `MON_IF.up_counter;
     // DUT needs a clk to load and start the counter
     if(`MON_IF.load_counter)
     seq_item_collected.current_value = `MON_IF.current_value;
     seq_item_collected.count_reached = `MON_IF.count_reached;
     seq_item_collected.print();
    // write into uvm_analysis_port for reference by next components
     trans_collected_port.write(seq_item_collected);
    end //if
 end //forever
 endtask : run_phase
But the problem I see here is:
Though i am setting load_counter = 1 in the first sequence, i see that monitor and scoreboard see the load_countrer =1 after 2 clocks(3rd sequence). i.e. I am just trying to figure out why is it so?
req.print(); of driver prints @15 :
# UVM_INFO updn_counter_driver.sv(69) @ 15: uvm_test_top.env.counter_agent.driver [DRIVER DEBUG1]
# Name            Type                   Size  Value
# req             updn_counter_seq_item  -     @673
#   count_value   integral               7     'h10
#   load_counter  integral               1     'h1
#   up_counter    integral               1     'h0
# UVM_INFO updn_counter_monitor.sv(45) @ 35: uvm_test_top.env.counter_agent.monitor [MONITOR DEBUG1]  seq_item_collected
# updn_counter_seq_item  updn_counter_seq_item  -     @643
anyone has any idea, if i am missing something here?
In reply to uvmsd:
Your monitor is going to send a transaction out every clock cycle regardless of any driver transaction (you should construct a new seq_item_collected for each object you write).
What does it show for the second transaction?
@dave_59
I spent good amount of time in debugging, analysing and going through below info:
http://www.sunburst-design.com/papers/CummingsSNUG2016AUS_VerificationTimingTesting.pdf
I changed my code as below and things are working.
**But i have a question:
I added below line before sampling the DUT outputs.
@(posedge counter_vif.monitor_cb);
**Will not above line add a clock cycle delay? what exactly does it do? please let me know.
   super.run_phase(phase);
 forever begin
    if (counter_vif.clk_en  && counter_vif.reset == 1) begin
     seq_item_collected.count_value   = counter_vif.count_value;
     seq_item_collected.load_counter  = counter_vif.load_counter;
     seq_item_collected.up_counter    = counter_vif.up_counter;
      // Sample DUT outputs with monitor clock
     seq_item_collected.current_value = counter_vif.current_value;
     seq_item_collected.count_reached = counter_vif.count_reached;
     seq_item_collected.sprint();
    end  //
 end //forever
 endtask : run_phase
In reply to uvmsd:
Can’t answer since you do not show the code in your interface. By yes, a clocking block adds another cycle. But once you introduce a clocking block, you should be using only that clocking block event and not the raw clk signal. Same is true for the signals you are trying to sample.
@dave_59
Here is my interface:
interface updn_counter_if(input logic clk, reset, clk_en);
//data and control fields
logic [ABSOLUTE_DATA_WIDTH-1:0] count_value;
logic load_counter;
logic up_counter;
logic [ABSOLUTE_DATA_WIDTH-1:0] current_value;
logic count_reached;
clocking driver_cb @(posedge clk);
default input #1 output #1;
output load_counter;
output count_value;
output up_counter;
input current_value;
input count_reached;
endclocking
clocking monitor_cb @(posedge clk);
input load_counter;
input count_value;
input up_counter;
endclocking
endinterface
You mean, I shouldn’t use @(posedge counter_vif.clk); in monitor to get the driving signals? Instead use
@(posedge counter_vif.driver_cb); while copying driving signals from interface? If so, how do I refer to clk_en?
Output sampling is done if (counter_vif.clk_en ==1), is that valid? I mean, are clk_en and monitor_cb be in sync?
Will @(posedge counter_vif.monitor_cb); add another clock cycle delay?
But the DUT and my TB values are matching. If above line had added one clk cycle delay, TB would have been 1 clk behind, right?
Sorry for more questions. I just wanted to get further clarity. Thank you!
