I have another question for you guys. I declared an unsigned dynamic array of bytes (therefore unpacked?!) which looks like this:
byte unsigned dchar_req [];
The dchar_req array shall be able to increase in size, whenever a new byte is available (a byte container if you like).
Inside a task, I have a queue (so another unpacked array) that contains 9 bits at a certain point.
Declaration and initialization:
logic actual_char_tx [$:8] = '{1,1,1,1,1,1,1,1,1};
At the mentioned point, I want to add a slice of the current content of actual_char_tx, i.e. the 8 right most bits, so actual_char_tx[1:8] as a byte
to the dynamic array.
dchar_req = new[dchar_req.size()+1](dchar_req); // Preserve previous array contents
dchar_req[dchar_req.size()-1] = actual_char_tx[1:8]; // Add queue slice to the resized dynamic array
The compiler output is as follows:
“Case item comparison: Cannot assign an unpacked type ‘reg []’ to a packed type ‘byte unsigned’.”
I’m confused about dchar_req being identified as a packed type although by declaration it is unpacked?!
