In this code I tried to implement some attributes of system verilog INTERFACE which are array of interface and array of moport.If I run the following code with any of the defined mode I get some “Unconnected Interface Port” error.Please let me know what to change in this code to make it functioning.Any suggestion would be appreciated.Thank you.
`define array_of_interface
interface intf;
logic [3:0] a,b;
logic c_in;
logic c_out;
logic [3:0] sum;
modport add(
input a,b,
input c_in,
output sum,
output c_out
modport sub (
input a,b,
output sum,
output c_out
endinterface
//Array of modport
`ifdef array_of_modport
module adder(intf.add i_bus);
assign {i_bus.c_out,i_bus.sum}=i_bus.a+i_bus.b+i_bus.c_in;
module subtractor(intf.sub i_bus);
assign {i_bus.c_out,i_bus.sum}=i_bus.a-i_bus.b;
module top_design (
output [7:0] con_sum [1:0],
output [1:0] c_out [1:0],
intf.add MODPORT_ADD [1:0],
intf.sub MODPORT_SUB [1:0]
adder con_add0(MODPORT_ADD[0]);
subtractor con_sub0(MODPORT_SUB[0]);
adder con_add1(MODPORT_ADD[1]);
subtractor con_sub1(MODPORT_SUB[1]);
assign con_sum[0]={MODPORT_ADD[0].sum,MODPORT_ADD[1].sum};
assign con_sum[1]={MODPORT_SUB[0].sum,MODPORT_SUB[1].sum};
assign c_out[0]={MODPORT_ADD[0].c_out,MODPORT_ADD[1].c_out};
assign c_out[1]={MODPORT_SUB[0].c_out,MODPORT_SUB[1].c_out};
`endif
//Array of interface
`ifdef array_of_interface
module top_design (
intf INTF_INS [1:0]
adder con_add0(INTF_INS[0].add);
subtractor con_sub0(INTF_INS[0].sub);
adder con_add1(INTF_INS[1].add);
subtractor con_sub1(INTF_INS[1].sub);
assign con_sum[0]={INTF_INS[0].add.sum,INTF_INS[1].add.sum};
assign con_sum[1]={INTF_INS[0].sub.sum,INTF_INS[1].sub.sum};
assign c_out[0]={INTF_INS[0].add.c_out,INTF_INS[1].add.c_out};
assign c_out[1]={INTF_INS[0].sub.c_out,INTF_INS[1].sub.c_out};
`endif
