"Undefined module: <interface> was used. Port connection rules will not be checked at such instantiations."
Below is the snippet of my code
Module top:
module top_tb;
  bit pclk;
  always #5 pclk = ~pclk;
  apb_intf apb_vif(pclk);
  port_intf port_vif();
    pclk = 0;
  top dt(/*signal connections to dut*/);
    uvm_config_db#(virtual apb_intf.m1)::set(null, "*", "vif1", apb_vif.m1);
    uvm_config_db#(virtual apb_intf.m2)::set(null, "*", "vif2", apb_vif.m2);
    uvm_config_db#(virtual port_intf)::set(null, "*", "vif", port_vif);
       run_test("my_test");
apb_interface:
interface apb_intf(input logic pclk);
  //signals
  clocking block1 @(posedge pclk);
    ///signals for driver
  endclocking
  clocking block2 @(posedge pclk);
    ////signals for monitor
  endclocking
  modport m1(clocking block1);
  modport m2(clocking block2);
endinterface
port_interface:
interface port_intf;
//signals
//no clocking blocks and modports used
endinterface
test:
  `uvm_component_utils(my_test)
  function new(string name = "my_test", uvm_component parent = null);
    super.new(name, parent);
// sequence handle
  env 				en;
  env_config		en_cfg;
  apb_agent_config	apb_agt_cfg;
  port_agent_config port_agt_cfg;
  function void build_phase (uvm_phase phase);
    super.build_phase(phase);
    en_cfg			= env_config::type_id::create("en_cfg");
    apb_agt_cfg		= apb_agent_config::type_id::create("apb_agt_cfg");
    port_agt_cfg	= port_agent_config::type_id::create("port_agt_cfg");
    if(!uvm_config_db #(virtual abp_intf.m1)::get( this, "", "vif1", apb_agt_cfg.vif1))
      `uvm_error(get_type_name(),("cannot get virtual apb_intf.m1"));
    if(!uvm_config_db #(virtual abp_intf.m2)::get( this, "", "vif2", apb_agt_cfg.vif2))
      `uvm_error(get_type_name(),("cannot get virtual apb_intf.m2"));
    if(!uvm_config_db #(virtual port_intf)::get( this, "", "vif", port_agt_cfg.vif))
      `uvm_error(get_type_name(),("cannot get virtual port_intf"));
    en_cfg.apb_agt_cfg	= apb_agt_cfg;
    en_cfg.port_agt_cfg	= port_agt_cfg;
    uvm_config_db #(env_config)::set( this, "*", "en_cfg", en_cfg);
    en				= env::type_id::create("en",this);
// seq creation
    super.run_phase(phase);
    phase.raise_objection(this, "RAL Test start");
   //starting seq on seqr
    phase.drop_objection(this, "RAL Test end");
endclass: my_test
apb_agent_config:
class apb_agent_config extends uvm_object;
   `uvm_object_utils(apb_agent_config)
   uvm_active_passive_enum active = UVM_ACTIVE;
  virtual apb_intf.m1 vif1;
  virtual abp_intf.m2 vif2;
   function new( string name = "apb_agent_config" );
      super.new(name);
port_agent_config:
class port_agent_config extends uvm_object;
   `uvm_object_utils(port_agent_config)
     virtual port_intf vif;
   function new( string name = "port_agent_config" );
      super.new(name);
env_config:
class env_config extends uvm_object;
  `uvm_object_utils(env_config)
  function new(string name = "env_config");
    super.new(name);
//switches
env:
class env extends uvm_env;
  `uvm_component_utils(env)
  apb_agent 	apb_agt;
  port_agent 	port_agt;
  env_config	en_cfg;
  // other component handles
  function new(string name="env",uvm_component parent=null);
    super.new(name,parent);
  // BUILD PHASE
    if(!uvm_config_db #(env_config)::get(this,"","en_cfg", en_cfg))
      `uvm_fatal(get_type_name(),("cannot get virtual en_cfg"));
      uvm_config_db#(apb_agent_config)::set( this, "*", "apb_agt_cfg", en_cfg.apb_agt_cfg);
      apb_agt		= apb_agent::type_id::create("apb_agt",this);
      uvm_config_db#(port_agent_config)::set( this, "*", "port_agt_cfg", en_cfg.port_agt_cfg);
      port_agt	= port_agent::type_id::create("port_agt",this);
//other component creations
  ////CONNECT PHASE
    // connections
apb_driver:
class apb_driver extends uvm_driver#(apb_seq_item);
  `uvm_component_utils(apb_driver)
  virtual apb_intf.m1 vif;
  function new(string name="apb_driver",uvm_component parent=null);
  // 		BUILD PHASE
    if(!uvm_config_db#(apb_agent_config)::get(this, "", "apb_agt_cfg", apb_agt_cfg))
      `uvm_fatal(get_type_name(),("cannot get apb_agt_cfg"));
  // 		CONNECT PHASE
    super.connect_phase(phase);
    vif	= apb_agt_cfg.vif1;
  // 		RUN PHASE
    //driving
apb_monitor:
class apb_monitor extends uvm_monitor;
  `uvm_component_utils(apb_monitor)
    //seq item handle
    //port
  virtual apb_intf.m2 vif;
  function new(string name = "apb_monitor", uvm_component parent = null);
  // 		BUILD PHASE
  // 		CONNECT PHASE
    vif	= apb_agt_cfg.vif2;
  // 		RUN_PHASE
    //capture
similar for port_driver and monitor. only difference is I am getting the apb_intf in port driver and monitor to use its clock.
I am getting the following errors and warnings:
WARNING VCP2515 “Undefined module: abp_intf was used. Port connection rules will not be checked at such instantiations.” “apb_agent_config.sv” 7 28
WARNING VCP2515 “Undefined module: abp_intf.abp_intf.m2 was used. Port connection rules will not be checked at such instantiations.” “apb_agent_config.sv” 7 28
WARNING VCP2515 “Undefined module: abp_intf.abp_intf.m1 was used. Port connection rules will not be checked at such instantiations.” “test.sv” 27 45
ERROR VCP2852 “Incompatible types at assignment: .apbvif ← this.apb_agt_cfg.vif2.” “port_monitor.sv” 33 31
ERROR VCP2852 “Incompatible types at assignment: .vif ← this.apb_agt_cfg.vif2.” “apb_monitor.sv” 27 27
I am not able debugg this. please help!
Don’t use modports. They are design constructs and shouldn’t be used for verification.
Always use the interface instance handle when referencing the interface.
No: virtual apb_intf.m1 vif1;
Yes: virtual apb_intf vif1;
No: uvm_config_db#(virtual apb_intf.m1)::set(null, ““, “vif1”, apb_vif.m1);
Yes: uvm_config_db#(virtual apb_intf)::set(null,”
”,“vif1”,apb_vif);
Thank you chuck. It helped me.
