Unable to compile a register model using registers of size 2048 bits
In reply to Marc43:
UVM_REG_DATA_WIDTH is a parameter used by the RAL. With +define+ you are specifying a macro but not a parameter. Best is to set UVM_REG_DATA_WIDTH in your RAL package to the correct value.
Thank you for your reply. Then doing
`define UVM_REG_DATA_WIDTH 2048
at the top of my RAL package, should work?
It does not work for me.
