Hello everyone,
I have a in my TB
force DUT_TOP_INST.vt =0;
#300ns;
force DUT_TOP_INST.vt =1;
Now i want to control this vt pad in my ovm_sequence how do i do that. I want to toggle it basically
Can i override force signal ??
Thanks in advance !
In reply to tejasakulu:
I believe you can apply the concepts in this paper to the OVM.
Thanks dave for reply. But i cannot override a force until i call release right? So i need to release it and then i can toggle; with force being on if i try to override it doesn’t work
Correct me if i’m wrong
One should never use force/release statements. BAD practice because of which you are running into the troubles. Use an interface and handle to the interface to manipulate the signals of those interfaces. I did a quick scan of white paper and describes the solution to your problem aptly.
-anil
Another force on a signal replaces an existing force—there’s no need to release it first.
Also, there’s no need to force to a literal constant. You can do
bit vr_reg;
initial force DUT_TOP_INST.vt =vr_reg;
#300ns;
vr_reg = ~vr_reg;
That way you can set up a driver to modify the value of vr_reg directly.
Thanks Dave
So you mean to say :
module testbench_top
bit vr_reg;
#300ns;
vr_reg = ~vr_reg;
interface test;
logic a;
endinterface
class driver;
virtual test vif;
new = ()
task test();
vif.vr_reg =1 ;
#200ns
vif.vr_reg = 0;
Let me know if this what you meant "setup the driver to modify the value of vr_reg"
You need to get rid of force statements and initial blocks. You can look at the following example in
$QUESTA_HOME/examples/systemverilog/interfaces/controller
DUT_TOP_INST.vt should be part of your interface signals to drive or sample.
You are almost there. keep at it.
-anil
