Hi
I want to Write a function to shift only odd bits for a 64-bit value by an odd shift number
for example, 64-bit values shift by 1,3,5,… but only odd bits to be shifted.
Hi
In reply to Svlearner:
That’s nice that you want to write this. If I give you the answer, then you would not have written it. I can suggest using a for-loop. It can be done in one statement if you do it in the correct direction.
Thanks for the push and hint Dave. I tried below code but i am confused on how to shift only odd bits. when we shift a vector all bits will be shifted right?
bit[7:0] a = 8'b1100_0110 ;
bit[7:0] b ;
for(bit[2:0] idx = 0 ; idx< 7 ; idx=idx+1'b1) begin
if (idx[0] ) begin
b = a << idx ;
$display("value of b %b",b);
$display("value of idx %d",idx);
$display("value of a a[%d] = %b ",idx,a[idx]);
Can you give me an example of a 64-bit value that you want shifted by how much? which direction. what would be a valid result?
It can be any value shifted by odd value and left shift.
Can you give me an example of a 64-bit value that you want shifted and what the result should be?
I got that as question from a friend from his interview so unfortunately i dont have examples… I was thinking… solution might not be using shift operator as shift operator will shift all the bits not just odd bits…
That doesn’t mean you cannot create an example with the result you are looking for without writing any code. That way a solution someone writes can be vetted against the desired result.
Here, i took a shot::
Bit [7:0] index;// – left shift value
Bit [63:0] num; // input number
bit [63:0] shift_num //outpu number
for(int i=0;i<63;i=i+1) begin
shift_num[i] = (i%2==1)? ((i-index>0)? num[i-index]: num[63-(index-i)]):num[i];
