SystemVerilog constraint implication with multiple variable
Hello,
I was wondering if it’s possible to use the implication with constraint for multiple variable in an elegant way?
constraint example {
flag == true -> other_flag_1 == false;
flag == true -> other_flag_2 == false;
flag == true -> other_flag_3 == false;
To be in pseudocode something like:
flag == true -> (other_flag_1 == false; other_flag_2 == false; other_flag_3 == false;);
Couldn’t figure out the syntax and couldn’t find something in the standard so maybe it’s not possible (and maybe worth adding?).
You could write the multiple constraints using if-else constraint as well ::
constraint example {  if ( flag == true )
                           //  Add  multiple  constraints  here
In reply to Ariel Elliassi:
The right hand side of an implication can be a constraint set:
flag == true -> {other_flag_1 == false;
                 other_flag_3 == false;};
Note that when your constraints are Boolean expressions, it’s the same as the logically ANDing them into one Boolean expression
flag == true ->  other_flag_1 == false &&
                 other_flag_2 == false &&
Thank you very much for the detailed explanation.
