I am relatively new to systemverilog and was wondering if i could get some guidance on classes. I have been trying to create a class which contains a function which when called will take a subclass name and instantiate it.I which two have two objects of the same class each with unique subclasses.
In reply to rbrtbrennan1:
You can’t pass the name of a type as an argument to a function. What you can do is either pass a string or some other encoded value as an argument and have the function branch to s statement that constructs the requires class, or you can use a proxy class object. A proxy class sole purpose is to stand in for the actual class you want to create with a virtual method.
class base;
class subclass1 extends base;
class subclass2 extends base;
virtual class base_proxy;
pure virtual function base create;
// this assumes T is a subclass of base
class wrapper #(type T) extends base_proxy;
virtual function T create;
create = new;
class A;
base b_h;
function myFunction(proxy proxy_h);
b_h = proxy_h.create();
Now in you can pass different wrapper class objects to your myFunction
base h1, h2;
h1 = wrapper#(subclass1)::new;
h2 = wrapper#(subclass2)::new;
myFunction(h1);
Proxy classes are used with the factory pattern. See my SystemVerilog OOP course, especially the third session of proxy classes and the factory.
You actually have no idea how much you have helped me, Thank you so much. I need to look over and read up on the course you have linked me but I have been tearing my hair out finding where to figure this out! Thank you!
