//write a constraint to generate 100 bit variable for 2 cases : 1) 7 bits are 1 at random places 2) 7 bits are random at continous places .
In reply to Ajit Gangad:
case : 1
rand bit [99:0] count ;
constraint c_100_bit { $countones(count) == 7 ; }
can you explain 2nd case little bit more
Thanks @dyno . for the first part of question . 2nd part of question is to generate continuous stream of 1’s (7 bits continuously )at random places of 100 bit variable.
Anyway I have written below SV code for the same and working as expected . Any other solution from your side is welcome .
class c;
rand bit[99:0]a;
rand int unsigned position ;
constraint c0{
position inside {[0:92]};
constraint c1{
$countones(a) == 7;
foreach(a[i]) {
if(i>=position && i < position +7 ) a[i]==1;
else a[i]==0;
module top_constraints;
c c1;
c1=new();
repeat(100) begin
c1.randomize();
$display ("%b",c1.a) ;
$stop;
Output-
#0011111110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
# 0000000000000000000000000001111111000000000000000000000000000000000000000000000000000000000000000000
# 0000000000000000000000000000000000000000000000000001111111000000000000000000000000000000000000000000
# 0001111111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
# 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000011111110000
# 0000000111111100000000000000000000000000000000000000000000000000000000000000000000000000000000000000
# 0111111100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
# 0000000000000000000000111111100000000000000000000000000000000000000000000000000000000000000000000000
Thanks @dave_59 . I am able to solve 2nd part of question with mentioned links .
https://verificationacademy.com/forums/systemverilog/i-want-constrained-random-10-bit-such-there-wont-be-7-consecutive-0s-or-1s.-can-someone-suggest-anything-thanks-advance.#reply-96719
