Hi all! I want to write an assertion for an N-stage synchronizer output (this synchronizer accounts for metastability modeling, so its delay is non-deterministic and it ranges in between N and M cycles).
This assertion needs to check that: a signal B can only change (from 0 to 1, or from 1 to 0) if and only if a signal A has changed (from 0 to 1, or from 1 to 0) in between [N:M] cycles in the past .
Thanks in advance!
property check_signal_b_change;
@(posedge clk)
($fell(signal_b) || $rose(signal_b)) |->
( ##[N:N+1] $changed(signal_a) );
Hi @liviareis ,
Assuming the clock edges occur at T0 ( 1st clock edge ) , T1 , T2 , T3 , … Tx,
N & M are constants with values 3 & 5 respectively.
If signal A changes at T2 then signal B should change at T5 or T6 or T7 ,
is this the expectation ?
Hi arshi582! No, according to your example, the assertion should check that: If signal B changes at T6 then signal A should have changed at T3 or T2 or T1 .
T0 T1 T2 T3 T4 T5 T6 T7
CLK __/‾‾\__/‾‾\__/‾‾\__/‾‾\__/‾‾\__/‾‾\__/‾‾\__/‾‾\__
B ____________________________________/‾‾‾‾‾‾‾‾‾‾‾‾‾
A ________________/‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾
-5 -4 -3 -2 -1 0
@(posedge clk)
( ##[N:M] $changed(signal_a) );
This is checking that, if B changes, then A should change from N to M cycles later.
What I want to check is: if B changes, then A should have changed in between [N:M] cycles in the past.
Currently this is what I have:
sequence A_rose;
@(posedge clk) $rose(A) ##[N:M] 1'b1;
endsequence
sequence A_fell;
@(posedge clk) $fell(A) ##[N:M] 1'b1;
endsequence
property B_CHANGED_DUE_TO_A;
@(posedge clk) disable iff (~rst_n)
$changed(B) |-> (B && A_rose.triggered) or (~B && A_fell.triggered);
assert property (B_CHANGED_DUE_TO_A);
If signal A changes at T6 then signal B should have changed at T3 or T2 or T1 .
sequence b2a_change( N , M );
$changed(b) ##[N:M] $changed(a);
endsequence
property b_2_a( N , M );
@(posedge clk) disable iff (!rst_n)
$changed(a) |→ b2a_change(N,M).triggered;
b2a:assert property( b_2_a(3,5) ) else `uvm_error(..)
Hi Have_A_Doubt , thanks for you reply but I didn’t see a big difference between your solution and the one I already have.
BTW, the issue I have with this solution is that during simulation, when B changes too close to the rising edge of the clock, the design and the sequence samples different values; the design samples 1 and the sequence samples 0.
D[0] _______ Q[0] _______ Q[1]
A ------->|D Q|------->|D Q|-------> B
| FF0 | | FF1 |
CLK ----->|>CK | -->|>CK |
A, D[0] ______________/‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾
Q[0] _______________/‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾
B, Q[1] ____________________/‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾
At T2, D[0] is 1 and Q[0] goes to 1. I’d expect that $rose(A) is true at T2, but it isn’t - it is only true at T3.
In this example, N=M=2 and the assertion fails at T4 (in which $rose(B) is true, but sequence A_rose is not triggered.
Anyone has an alternative solution or a solution for the issue I am having?
Thanks!
liviareis:
| FF0 | | FF1 |
Considering that both design and concurrent assertions use sampled value ,
why is it that Q[0] is 1 just after T2 ?. Sampled value of D[0] at T2 would be 0
chr_sue
December 18, 2025, 9:57am
10
@liviareis : I’d sample your assertions on the falling edge of your clock. This avoids the prblems you are facing.
