Yes, behavior of this block is similar to FIFO.
(valid_l, v_d=data_l)
- what does it mean? when ‘valid_l’ then ‘v_d=data_l’?
May this command be presented as ([condition],[expression])? Where can I read a full description of the command?
I don’t see how ‘valid_r’ is participated in the checks… Can the above be re-written in the following way:
@(posedge clk) (valid_l, v_d=data_l) |-> ##[1:UPPER] valid_r ##0 data_r==v_d;
Thank you!
P.S. what’s the name of the ([condition],[expression]) function? If I want to read its full description, what’s function name should I search for in the books?
