In reply to CPU_Verif:
The solution explained in the book is incorrect because it does not meet the following requirement:
“Making sure that bmode is not high while oe and dack are high”
What it does instead is:
“Making sure that bmode is not high for 2 cycles and then when oe and dack are high”
Below are my untested changes
//Solution explained using throught
sequence data transfer; // 6 cycles in length
##2 ((dack ==1) && (oe==1))[*4];
//After 2 cycles the oe and dack are high for 4 cycles continuous
endsequence
sequence checkbmode;
(!bmode) throughout data_transfer;
//Making sure that bmode is not high for 2 cycles and then when oe and dack are high
endsequence
@(posedge clk) $fell(bmode) |-> checkbmode;
//Making sure that bmode is not high only when oe and dack are high
// In other words, (dack==1 && oe==1 && !bmode)[*4];
property pbrule1a; // simplified to
@(posedge clk) $fell(bmode) |-> ##2 (dack==1 && oe==1 && !bmode)[*4];
property pbrule1b;
(dack ==1 && oe==1[*4] intersect !bmode[*4]);
endsequence
property pbrule1c;
@(posedge clk) $fell(bmode) |-> (##2 dack==1 && oe==1[*4]) intersect !bmode[*6]; // 6 cycles total
Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb - Papers:
Verification Horizons - July 2020 | Verification Academy - Reflections on Users’ Experiences with SVA
Reflections on Users’ Experiences with SVA | Verification Horizons - March 2022 | Verification Academy - SVA Alternative for Complex Assertions
