Strong and #-# of SVA
Please help. I am confused with #-# operator of SVA.
I thought the following two properties were equal.
// strong usage
$rose(s1) |-> strong(##[0:$] ##0 $rose(s2))
// #-# operator usage
$rose(s1) #-#        ##[0:$] ##0 $rose(s2)
However, it looks it is not correct.
The following tests were applied to these properties.
# === TEST 1 :         ________________
# s1 :  ______________|           _____
# s2 :  _________________________|
# === TEST 2 :          _______________
# s1 :  _______________|
# s2 :  _______________________________
I expected both property gets PASS in TEST 1 and FAIL in TEST 2 since s2 never goes high.
However, the result is
strong usage :
PASS in TEST 1, FAIL in TEST 2
(As expected)
#-# operator usage :
FAIL in TEST 1, FAIL in TEST 2
Looks fails at every clock cycle.
Here is EDA Playground link : https://www.edaplayground.com/x/vWKi
Is #-# operator different from strong? What is it and what is happening in the sim of the EDA Playground ?
property_expr ::=
| strong ( sequence_expr )
| sequence_expr #-# property_expr
| sequence_expr #=# property_expr
There is NO implication here. #-# is equivalent to ##0 if you substitute
property_expr with sequence.
So the #-# just says
sequence_expr is followed by a property_expr in a manner similar to
sequence ##0 sequence says a sequence followed by another sequence.
en Cohen
Ben@systemverilog.us
rose(s1) #-# ##[0:] ##0 $rose(s2)
Thanks @user49 ,
I understand that #-#, #=# don’t have meaning of implication unlike |->, |=>. Therefore, the check is done at every clock. A few articles says no vacuous pass with followed-by operator, #-#, #=#. But they are NOT implication property. So, check is done at every clock unless there is implication before them. Therefore, no vacuous pass in that sense. I misunderstood it and I thought strong attribute can be applied with #-#. I guess the person who created the following post made the same misunderstanding as me.
Usually, #-# is used to combine two properties as follows.
A |-> B #-# C |-> D
And, I think this is equivalent to the following two properties.
A |-> B
A ##0 B ##0 C |-> D
In this sense, followed-by operators are different from simple concatenation of implication.
A |-> B |-> C |-> D
is equal to
A |-> B
A ##0 B |-> C
A ##0 B ##0 C |-> D
I believe my understanding is correct now.
[YOU] Usually, #-# is used to combine two properties as follows.
[Ben] #-# is used to combine a sequence to a property
A |-> B #-# C |-> D
    B is the sequene
    C |-> D  is the property
A |-> B #-# C |-> D  is equivalent to
A |-> (B #-# (C |-> D)))
      (B #-# C) |-> D   // ILLEGAL
All the other interpretations are incorrect
Hi @user49 ,
I’m a bit confused.
What is the difference of the followings?
B #-# (C |-> D)
B ##0 C |-> D
Are these same? What is #-# for in that case?
Difference between
"B #-# (C |-> D)" and "B ##0 C |-> D"?
A: B #-# (C |-> D)
  B is a sequence
 (C |->D) is a property
if B==0 then ( B #-# (C |-> D)) property is false (Fails in an assertion)
(B #-# C) |-> D is illegal because (B #-# C) is a property
B ##0 C |-> D
B ##0 C is a sequence and is an antecedent
D is sequence treated as a property in the consequent
if B==0 then (B ##0 C |-> D) property is vacuously true, (vacuous in an assertion)
Thanks @user49 ,
Then, what about the case of (B == 1) and (C == 0)?
B ##0 C |-> D is obviously vacuous pass in this case.
Is B #-# (C |-> D) vacuous pass or fail?
If B==1, then you evaluate the property C |-> D
By now, you should know that if C==0 then property is vacuous.
Assertion is thus vacuously true
