Streaming 32-bit to 8-bit
I am trying to stream each byte of a 32-bit word in a queue like so:
bit [31:0] queue[$];
bit[7:0]   data;
foreach(queue[i]) begin
    for (int j=0; j<4; j++) begin
        data = {data, {>> 8{queue[i]}}};
However, this only fetches the least-significant byte of the queue. What is the proper syntax to stream each byte from the queue?
In reply to Robert.Lanier:
We don’t know the byte ordering you want. It would help if you gave some sample values and showed how you wanted data to be streamed. For example
  bit [31:0] queue[$] = {32'h01234567,32'h89ABCDEF};
  bit[7:0]   data;
  initial
    foreach(queue[i])
        data = queue[i][j*8+:8];
        $displayh(data);
Displays
# 67
# 45
# 23
# 01
# ef
# cd
# ab
# 89
bit[7:0]   data;
initial
foreach(queue[i])
$displayh(data);
Displays
# 67
# 45
# 23
# 01
# ef
# cd
# ab
# 89
I should have mentioned I am trying to fetch LSB first, thank you for pointing this out.
I had started using the same solution you have shown, but preferred to use the streaming concept rather rather than specific values from the data word. However, after reviewing section 11.5.1 Vector bit-select and part-select addressing of the SystemVerilog LRM (1800-2017), this is the solution I was looking for.
Thank you again for the help!
If you really wanted to use the streaming operator, data would have to be defined as a queue.
  bit[7:0]   data[$];
      queue.reverse;
      data = {<<8{queue}  };
      $displayh("%p",data);
bit[7:0]   data[$];
queue.reverse;
Is this because the LHS and RHS need to be of the same type when using a streaming operator?
The LHS has to have enough bits (or dynamically resized) to hold all the bits on the RHS.
i want to generate a constraint for the sequence 101100111000… without using pre and post randomize
I cannot see what this has to do with the previous question. Please post this as a new topic. It would also help if you provided an example, demonstrating exactly how you want the sequence to be generated with non-random code.
