Sequence Library
I want to configure all the sequences added in the sequence library. what are the ways to do it?
In reply to Nandakumari:
https://verificationacademy.com/cookbook/config/configuringsequences
//collection of multiple sequences
class seq_library extends uvm_sequence_library#(apb_sequence_item);
//factory registration
uvm_object_utils(seq_library) uvm_sequence_library_utils(seq_library)
randc int slave_id;
apb_seq_config seq_cfg;
function new(string name = “seq_library”);
super.new(name);
seq_cfg = apb_seq_config::type_id::create(“seq_cfg”);
//adding sequences here
// add_typewide_sequence(apb_base_sequence::get_type());
// add_typewide_sequence(apb_wr_sequence::get_type());
//add_typewide_sequence(apb_rd_sequence::get_type());
add_typewide_sequence(apb_wr_rd_seq::get_type());
constraint slave_no_con {slave_id inside {[0:`NO_SLAVES]};}
virtual task body();
//storing seq config class in db
seq_cfg.configure(slave_id);
uvm_config_db #(apb_seq_config)::set(null,“*”, “apb_seq_config”, seq_cfg);
 super.body();
endclass:seq_library
//base sequence code
class apb_base_sequence extends uvm_sequence#(apb_sequence_item);
`uvm_object_utils(apb_base_sequence)
//variables to hold configured addresses
bit[ADDR_WIDTH - 1 : 0] start_addr; bit [ADDR_WIDTH - 1 : 0] end_addr;
int count;
function new (string name = “”);
super.new(name);
endfunction :new
if ( !uvm_config_db#(apb_seq_config)::get(null, “*”, “apb_seq_config”, seq_cfg) )
`uvm_error(get_type_name(), “Failed to get config object”)
start_addr = seq_cfg.SLAVE_ADDRESS_MIN;
end_addr = seq_cfg.SLAVE_ADDRESS_MAX;
count = seq_cfg.count;
   `uvm_info(get_full_name(),$sformatf("MIN ADDR = %0d,MAX_ADDR = %0d",start_addr,end_addr),UVM_LOW);
endtask :body
endclass :apb_base_sequence
is it okay that the sequence have a dependency on sequence library like this? is there any other better ways to make this sequence more configurable and reusable?
You don;t need UVM’s sequence library. See https://verificationacademy.com/forums/uvm/can-we-use-sequence-libraries-sequences-running-different-sequencers#reply-110964
