Can we add sequences running on different sequencers in the sequence library ?
In reply to dsherlek:
A uvm_sequence_library runs on a single sequencer. You can add a sequence to multiple sequence libraries.
It is easy to build your own sequence library out using a simple array. See Generic sequence call on different sequencers | Verification Academy. This avoids having to hard code any sequence to a particular sequencer.
Does that mean that the UVM sequence library doesnt support running Sequences on different Sequencers ? And the user has to create an array mechanism to create a sequence library of their own ?
