m_r_m
July 9, 2021, 4:09pm
1
generate
for( genvar slice =0; slice <WRAPPER-1; slice++)begin
`active_rst_assert(m_reset[slice])
`active_rst_deassert(m_reset[slice],m_clk[slice])
endgenerate
xmvlog: E,SVNPSN (file.sv, **): The value in the single-bound form of a range must be positive.
I have used `define macros for the multi use of the property, wanted to use the same property(checking for the reset) for the multiple instances.
In reply to muku_383 :
`define text macros get expanded before any SystemVerilog code gets parsed. Can you use your property directly with arguments?
Your issue , as dave said, is the argument m_reste[slice] since the macro is expanded before if gets evaluated. You should use a temp var to store it before and then assign. Regards
In reply to Rsignori92 :
Without seeing the macro definition it’s impossible to suggest an alternative.
m_r_m
July 10, 2021, 2:01am
5
In reply to dave_59 :
`define ah_rst_assert(val)\
bit ``val``_tb;\
always @(posedge ``val``_in)begin\
//logic\
end\
property ss_``val``_in_assert_property;\
// logic\
endproperty\
`define trigger_assertions(val,assert_deassert)\
``val``_in_``assert_deassert``_check:assert property(ss_``val``_in_``assert_deassert``_property);\
`ah_rst_assert(ss_rst)
`trigger_assertions(ss_rst,assert)
generate
endgenerate // error
I hope this might help.
m_r_m
July 10, 2021, 8:57am
7
I will rewrite the complete code for you and share the EDA playground link.
